LexusAllTerrain
Are there any issues sleeping inside the vehicle with a 5 lbs propane tank inside when cold weather? My question is because I know we carry 1 lbs baby cans inside when transporting. So is there a difference?
Do you sleep in same quarters? I am planning on small heater inside my vehicle before sleeping and early mornings...your thoughts? It will be a Mr. heater !We always carry a 5 lb. inside the vehicle and use a brass valve cap as an extra precaution.
We sleep in the same quarters, however only use the propane tank to run a water heater for hot showers when rear doors are open (Ford E250). For warmth we use a Planar (run it on kerosene) heater that sits outside the van when in use, i.e. no combustion inside the van.Do you sleep in same quarters? I am planning on small heater inside my vehicle before sleeping and early mornings...your thoughts? It will be a Mr. heater !
