96 Land Cruiser, White, VERY clean fully kitted Overland expedition rig $59,000.00
Wow! I can't believe how clean your vehicles are! And it appears that you actually use them as they are intended to be used....but they still look like they just came off the showroom floor! I'm shaking my head in wonder.
This thing is out of my league, but whoever buys it is really going to enjoy it! GLWS!
GLWS That is one mighty fine 80. I like the cut and zipped rear mud flaps, I'll be using that one. How did you mount the Blue Sea fuse block to your second battery? Is that the only fuse block your using or do you have one in the cab as well? Also looking forward to seeing your maintenance log on your site.
Why thank you, yes the mudflap trick comes in handy, I tie wrapped the Blue Sea to the battery handle, it is very secure and can be removed if needed. There is 1 more fuse panel in cab. Maintenance coming soon as time permits.
Sethro
Hot water shower hook up
No rust and very clean undercarriage
Shot of the 20 gallon water tank and trailer wire hook up
Original paint
Cleanest 80 I've every seen. Wow - Nice!
PS - one of the strapping bolts holding the water tank is about to fall off : )
thank you :)
The nut is a lock nut and is set like that for proper tension on the plastic tank, I agree it does look like it is ready to fall off, thats just where the proper tension ended up, thanks for the heads up though
Sethro
rocksandtrails
