spressomon
Here’s a brief description:
• Bought new from AT 2 ½ years ago
• Custom Fox Shock Coil-Over Spring/Shocks with Remotes for incredible adjustability, tune-ability and control/performance.
• Dual fuel can holder (being sold without fuel cans)
• 19-gallon water tank
• Fiamma awning
• Deluxe battery charger & built in shore plug
• 2- Lifeline Group 31 AGM marine batteries
• Aquajet water pump mounted in nose box (used for showers; shower apparatus not included)
• Electric drum brakes
• 1-year old Maggiolina Grand Tour Medium with custom made latex mattress (this IS NOT a temperature sensitive memory foam type of mattress): Uber comfie!
• Custom ladder and quick release mounting system: Ladder quickly and securely attaches to the top of the DS side box (eliminates the pressure point on the Maggiolina fiberglass)
• Loc n Roll multi-axis coupler
• Custom quick to attach/detach leveling jacks (attach to rear bumper)
• 2-Propane mounts (propane bottles included)
• Kelty Carport Deluxe included (attaches to aluminum “L” channel that is fixed to the Maggiolina)
• AT Stainless Steel sink
• Toyota 5x150x14mm hubs and 4” spacer adapters
• Toyota Land Cruiser OEM 8” x 16” alloy wheels
• Goodyear MT/R 315R75 16” tires
• Rubber mat and hold down loops in box
• Extra 12V outlets
• Integrated Steel Partner dual burner stove
• Upgraded heat treated swing arm spindles
This trailer has the typical stone rash on the outside edges of the front frame section and front facing side box panels: Line-X or similar would be the best solution (was not offered when I purchased this trailer from AT). It took a hit to the PS side box which is cosmetic and has not affected use and/or dust/water sealing on that side.
I want $10,500 for it with everything as described (less than ½ price of new as presented). I’m not interested in selling the trailer and Maggiolina separately unless there are two parties interested in each at the same time.
• Fiamma awning
• Extra 12V outlets
