Let me get this straight...
You are worried about
Weight
wind drag
MPG
And you buy an ambo??
Didnt you read the FAQ?![]()
Larger turning radius? NOPE. Try TIGHTER with the 4wd.
Lifting the rig to allow the solid front axle allows for a tighter turning radius.
Question: I'm working on a type II ambulance. Are the house batteries isolated from the starting batteries? ( 7.3)
I've got over 25,000 miles on Forest Service Roads in 2WD, and don't need 4WD. I admire U-Joint kits, I just don't need one.
All of my 4wd ford vans had a worse turning circle than my 2wd versions (2 Quigley and 1 Advanced 4WD). But my 2wd Freightliner has a great turning circle and will stay 2wd for that reason.
Also you forgot the driveline maintenance added with 4WD. You have transfer case with bearings, seals and uni joints. A driveshaft with uni joints, the axles and in some cases the unis/CV's in them. Plus the added unsprung weight affects the level of damping/suspension required.
