ARB Fridge question
Very easy repair. Had to replace the thermistor on mine. Just follow the directions from ARB and you should be good to go. Just take your time when cutting through the bottom of your fridge.
Well just finished the repair. Won’t know if it works (or if I did it right) till the morning. Keeping fingers crossed?
Took a few hours but got it fixed. It was the thermistor. Mine is an original “Not user replaceable thermistor“ model so you definitely need to cut a hole in the fridge and dig out all the foam carefully. Then snip off the tip of the old thermistor and splice in the new tip using phone jelly connections. Then plate the hole and use canned foam to re-insulate the hole. Flip fridge back upright and let sit for a few hours, recalibrate the display and then BOOM! Works like a charm. Thanks ARB and forum dudes. Got R Done.
NorthCaptiva
