ARB Fridge question
I bought the new ARB fridge and got the complete package of Bag, slider and tie down straps last spring. I have runned it with the TB on it since day 1 so I can't vouch for its ability to keep fridge cooler (although It couldn't hurt) but it helps in the protection of fridge for sure. The pain of paying for all the "extra's" has long since subsided, but still reaping the benefits of a securely tied downed and protected fridge. :smiley_drive:
Where is your slider bolted down?
I have a FJ Cruiser and I have removed the rear seats and custom fabbed
a aluminum rack that is bolted down to the seat mounts and the rear tie down points and the fridge/slide is bolted to the rack It is very solid and lightwieght. I guess the hard part of mounting a fridge/slider is finding a suitable place to bolt to. Since I had no need for the rear seats, it was a easy way to accomplish that goal.I also have a aluminum dry box bolted to the rack where the seats would be, It is large enough to stow all my recovery gear, tools and most of my camp kitchen in and our dog rides on top of it. next to the fridge will be a small 10-15 gal water tank once I find the right size/shape tank
It arrived the other day. First impressions are that it will help prevent dings and scratches, but I have yet to see whether it helps the fridge cycle less. I will be monitoring my battery voltage this week and will post my findings.
After having the transit bag for a while, it definitely helps prevent scratches and dings, however I am still unsure about conserving battery life. It seems like it helps slightly, but it has been on the colder side here recently, so it's hard to pinpoint the exact cause.
It's still a good investment, but don't buy it for "less cycling" alone because it's not a drastic change.
It does help with the cycling, mostly in the warmer months, does not run for so long and cycles less in the winter but you are also protecting your investment, I think is worth allot.
Looks like you have it tied down pretty well, you definetly don't want it flying around inside your vehicle if by chance you are involed in a wreck or turn it upside down. Beauty of the new ARB fridge is that the handles are alot more stout than the old ones and you can cinched down on them pretty hard. In the picture it looks like you have items covering the vent I would make sure to keep a couples of inches clearance around both vents for proper running of fridge. Enjoy your new fridge, I use mine all the time. Its great when I go grocery shopping especially during the summer Ice cream isn't a soggy mess when i get home!
Most of the comments on this thread are from users using the transit bag on older ARB/Engel fridges. I am "guessing" the new ARB fridge is better insulated and thus might not benefit as much from a TB as the older fridges.
I think you may be correct because there aren't any drastic changes other than protection.
I have been noticing large amounts of moisture/condensation underneath my weathertech cargo liner around where my fridge is. The bottom of the liner and the carpet get wet enough that I can see droplets. Has anyone else experienced this or know a solution?
Bump to a more appropriate time.
I run my ARB fridge (gen before the new model like yours) all the time, and I do not see any condensation in my rig.
Mine sits on an Engel SlideLock, then the back of the fold down seats which is backed with plastic.
I have the bag more for protection.. to be honest .. the velcro it comes with is junk and won't stick to the plastic on the front edges. I've cleaned it replaced it some other velcro and still won't stick, I'm looking for some high quality from 3m right now to fix the problem.. or some silicone RTV.
Just a little insight to what I've experienced
Those of you running ARB fridges.... Do you use the transit bag? I can't decide if they are worth it or not. Good quality? Does it look tacky? Does it help the fridge cycle less? Etc.
Much appreciated
I haven't felt Ive needed it but then again I store it above my drawer system in my rig and the only thing else up there are light fluffy things like my sleeping bag, thermarest pad, backpack/duffel bag with clothes, etc.
:ylsmoke:
As for helping insulate it, I've only really began using it last fall (bought it last spring/summer) so I can't say it helps during the summer months.
For me there has been no noticeable condensation on the carpeted surface I run it on.
I will have to try to isolate the cause.
Do you all run the fridge 24/7 or do you keep it off for periods of time? I have a dual battery setup but the truck often sits all day since work is only a couple miles from home so it drains pretty fast. Is it hard enough on the fridge to unplug it now and then that should I invest a couple hundred dollars into a solar panel?
Camp Tonneau Tents
