Romer
Anyone use one of these yet? I heard Martyn is working up a project.
http://www.adventuretrailers.com/heaters.html
Where to mount the thing on my Horizon seems like the biggest challenge, but I was thinking of bolting a custom box on to the front of the drivers side side box.
Right were the 3 bolts are (From PO isntalled CO2 Tank)
Then make it so the flexible hose could just sit in the changing room.
I would need to consider how hot it gets to determine the proper mounting enclosure and heat disappation path.
I installed a 2nd propane tank right below this spot to use for the heater.
Hoping someone has blased the trail and I wanted to make sure they put out enough heat, assuming I would need the larger one. Current draw is great compared to a popup heater, but does that reduce the performance enough that is doesn't do the job
