AUX FUEL TANK???
ujoint
Supporting Sponsor
We're making a 39 gallon midship replacement tank for 4wd conversions, that may meet your needs.
Production starts early feb.
ujoint
Supporting Sponsor
Yep! We'll be starting with the tanks that have the bolt in sending unit, then moving to the lock style. More details soon as we start production.
dansvan
If you remove the spare tire mount assembly from the rear frame portion, you can put a rear tank from a mid 90's ford f series in its place. If you use the 15 gallon or so you can use the factory skid and its flush with the bottom of the frame rails. Or put a 40 gallon bronco tank in and loose departure angle. Filler has to be figured out, I ran mine up through floor and out under the left rear tail light. No not a bolt in but cheap and effective.
Sfreeman
