high-and-dry
Okay first some specs. Over all trailer width will be 5'6 to 5'8", I want fenders on it so I want about 3 to 4 inches of tire/wheel past the wall. I want to use toyota rims which are 6 lug 5.5" and I think the rims have 4.5 from the inside of the rim offset. Tire size 31 10.5 r15.
I think I want a axle length hub to hub of 60 inches, and my frame rails should be outside width of 46 inches. Pretty sure that works out to about 2 to 2.5 inches of frame clearance from the tire. Due to tire height I am pretty sure a 0 degree angle on the arms which should give me 16 or ground clearance to frame.. I want the option for brakes, maybe now maybe later.
Okay I would love timbren axles but I would love to not spend that much. I dont want spring axles, so that leaves me flexiride or dexter torsion axle. It does not appear I can do the 6 x 5.5 lug pattern on the flexiride but can on the dexter.
I think I will need the dexter 3500 axle, can the rubber be down sized to a wet weight of around 1500. What should I am for for the rubber rating?
Edit i found a place that looks like I can get it with brakes for right around 500, who is the cheapest for something like this?
