AxleIke's First Gen 4Runner- Baby Beast
AxleIke
Hello!
I'm Isaac, live in Gunbarrel Colorado, and I'm new here. I've been around a bit, and LOVE this site, though my wallet hates it!
Figured I'd start my own thread, since, with the near completetion of his trailer, my partner in crime REZARF and I should be up and about doing some "mini" expeditions!
The truck:
1987 4runner.
292k
22re 5speed.
My mods:
Suspension
Front:
1.5" SDORI Ball joint spacers
OME torsion bars.
Front end relaxed down, so that truck sits at stock height.
Downey Idler Arm Brace
OME Shocks.
Sonoran Steel Rear IFS crossmember
Rear:
Downey 3" springs (crap)
1.5" lift shackles.
Bilstein 5100 Shocks.
Tires:
33x9.50R15 BFG All Terrains.
Wheels:
Currently stock toyota Aluminum
Previous black steelies
(I like the aluminum a lot better)
Armor
Sliders built by me (need to be replaced as I used steel that was too thin)
Budbuilt Budlight Tranny/Transfer cross member.
Front belly skid built by me: 3/16", angle reinforced steel
ARB Bull Bar
Rear bumper built by me.
Drivetrain
Stock 5speed transmission
Marlin Dual Ultimate Crawler
4.88 Precision Gears
ARB Air Lockers Front/Rear
QuickChange CV mod.
Other
CB
Sirius
Rocklights
Diffbreathers
What I plan on doing for the next step is building a rear tool area, which will give me a place to stow all of my tools out of the way, and give me a good base for gear, and maybe someday when I win the lottery, a slide for my engel... :D
PICS: (I need to get one with the new wheels)
AxleIke
Here's my Rear ARB Install:
(I copied it from another forum, sorry if some of it isn't relavent)
This write up is detailing the installation of an ARB Air Locker. However, the same techniques will be applied when installing ANY other carrier-replacement locker (Detroit, spool, etc). However, if you are replacing gears, this write up DOES NOT COVER A RING AND PINION INSTALL.
I would first like to thank my good friend Drew Frazer for helping me with this install. His help was invaluable, as was his wit and good attitude helped as much as his mechanical skill.
Also, much of this was learned from the website http://www.gearinstalls.com This is ZUK's website, and details everything that I’m about to put down here, and then some.
Disassembly​
I recommend loosening the driveshaft before you remove the rear wheels from the ground. If not, it can be difficult to keep the wheels from turning. Next, drain the differential, using the drain plug. This will help to keep down on the mess as you remove axles and the housing.
Remove the rear wheels, unbolt the rear axles (located on the back of the brake drums.) Make sure that you have your ebrake off, and remove the ebrake cable. Also disconnect the rear brake lines from the drum assembly.
Remove the drum assembly and axle. Repeat for the other side.
Your removed axle piece should look like this:
Next is the removal of the third member. Undo all of the nuts on the studs, and use a jack to carefully break the seal on the housing. DO NOT PUSH HARD. You do not wish to break the studs off. Slight pressure will allow the seal to break, as the third has SOME play on the studs themselves. See Pics:
As you can see, my driveshaft was stuck to the diff slightly, so I left it on until I got the diff out. It is infinitely easier to remove the drive shaft after the third is able to move around a bit.
Now that the third is out of the truck, it is time to begin disassembling the differential. Your truck will not be operable at this point, so make sure you have other modes of transportation if you need parts:
The first thing to do is to mark the carrier bearing caps with a punch. The pictures aren’t great, but they show the mark I made with a soapstone pointing to my single punch. In the pictures, the cap itself isn’t on anymore. However, you will be able to see what I mean when you pull yours out. Simply mark the cap and the housing with a single punch on one side, and a double punch on the other. This will ensure that you get the caps back on the correct side, and in the correct orientation.
AxleIke
In order to remove the bearing caps, and to correctly reassemble the carrier, you must build a small tool. Get a piece of steel strip from the hardware store, and cut it to 3 inches. Purchase one half inch grade 8 bolt, and two 5/16” grade 8 bolts. Next, drill a hole in the center of the 3” steel strip, and the other two holes 2.5” center to center. The size of hole you drill will depend on how you attach the bolts. I chose to weld. You can also tap the holes, and screw the bolts in, but that will make it more difficult to loosen using this tool. This will allow you to loosen and tighten the carrier bearing adjusting nuts.
After removing the carrier bearing caps, you can remove the differential. In my case, a Detroit Trutrac, previously installed. Now, you must remove the ring gear. These are on there tight, with threadlocker, so you’ll need some leverage. Excuse the goofy guy in the pic (me). I purchased new bearings with my Air Locker (I highly recommend this), but if you choose to reuse your old ones, you will also have to remove the bearings from your old carrier.
Reassembly​
Now is decision time. I chose to bring my locker, ring gear, and bearings to a guy I know with a press, and have him press on everything. This just gives me peace of mind, since this is my primary drive axle. However, a year ago, on my front ARB, I used a different method. WARNING: I am a young bachelor, and the following method can really make a mess of things. Check with your wife, or husband, before attempting this method. I will explain in a moment. Metal has a pretty decent coefficient of thermal expansion, enough anyway, to make use of it to get bearings and gears on. Set your oven at 200 deg, and put your locker into the freezer. Once, at 200 deg, put one bearing in. Let it sit for about 20 mins, enough time for it to completely heat. Take out the locker, put in on the bench, and then, using a pair of pliers, move the bearing out. Push the bearing onto the locker. You must do this quickly, or it will not work. Repeat for the other bearing, and the ring gear. Be sure the bearings and ring gear are flush seated on the locker. Also, make sure the ring gear bolt holes line up. Now, here is my warning: After I did this, I did not clean my oven. I cooked a pizza in there about 2 weeks later, and, you guessed it: Pepperoni and 90 weight. Needless to say, lesson learned. You must clean your oven thoroughly after this, both scrubbing and with a clean cycle.
Lastly, if you install the ring gear yourself, be sure to torque down the ring gear bolts to 70 foot-pounds
Next is time to reassemble the carrier into the housing, and set the backlash.
For me, it was time to drill out the hole in the third for my bulkhead fitting. ARB’s instructions are top notch, and will detail everything very carefully.
Next, place the carrier and ring gear into the housing, making sure to remember the bearing races, and replace the carrier bearing caps. Be sure to get them on the right side. This is where you match up the one dot and two dot marks you made earlier. Put in the ring gear bolts. Locktite is recommended here as well. However, at this point, only hand tighten the carrier bearing cap bolts. I hand tightened, then used a wrench with about 1/8th to ¼ turn to be sure the bearing caps were snug.
Be sure that the threads inside the cap and the housing are PERFECTLY lined up. I used a small hammer to adjust the caps side to side until the threads were lined up on both sides of the carrier. Now, put in the carrier bearing adjusting nuts, and screw them in hand tight.
Pre carrier bearing adjusting nuts
Here you can see the supplied adjusting nut installed. On the ARB, they supply you with a new adjusting nut for the airline side of the locker, and one old one for the opposite side. For other lockers, you will reuse your old adjusting nuts.
You can also see my harbor freight Dial Indicator and Mag base, purchased for 10 dollars each. These are a MUST HAVE if doing this type of installation. Setting the correct ring gear backlash is CRITICAL for having a long gear life, and gears that will hold up under abuse. Too much backlash, and the gears will deflect and chip, and too little and the gears cannot get enough oil, and will fail very quickly. Backlash is measured in thousandths of an inch, so the dial indicator is very important.
Let me next give a quick explanation of backlash. I describe backlash as the amount of “wiggle” that the ring gear has. The ring and pinion need a certain amount of space between them, and that space is measured by the amount of movement that the ring gear has when the pinion is stationary.
Good backlash values, according to ZUK, who does excellent gear installs, would be about 6 or 7 thousandths. I have heard that any value between 6 and 12 is acceptable, though I personally would never go above ten.
You measure the backlash by contacting the tip of the dial indicator at a right angle with the ring gear tooth you are measuring off of. Press it in a bit, so that you can get a good reading by moving the gear one way, and then the other, until it stops in both directions. The difference between your two measured values is your backlash.
Now, two things need to happen at the same time for this next step. You need to set your backlash, and you need to set your carrier bearing preload. You adjust the backlash by tightening and loosening the adjuster nuts. And you set your preload by torqueing the adjuster nuts to at least 100 ft lbs. Use a torque wrench and the handy adjuster nut wrench you built earlier.
I adjusted the setting on my torque wrench at 85 foot lbs, and moving back and forth until I had a pretty acceptable backlash of .008. I then moved back and forth from one side to the other until I clicked at 85.
AxleIke
I then stepped up in 5 lb increments to 100, making sure to adjust each side the same amount each time. After each tightening, be sure to tap the bearing caps and the housing by the bearings with a hammer to help seat the bearings properly.
This process took about an hour, but it is worth it to get the backlash set up correctly so your gears last a very long time.
Opposite side with original adjuster nut installed
If you are installing a non-ARB locker, you are done here. I still had to assemble my air set up for the diff. Follow ARB’s instructions, which are simple, and very detailed.
Here is a shot of the air line set up:
Follow the directions about bending the airline around the ring gear. Be sure there is plenty of clearance between the ring gear and the copper air line. If that line hits that ring gear, it will end your day quick.
Bench testing the locker :p
Actually we bench tested the locker using 90 lbs of CO2 from a tank, and a special fitting I built for testing the front one. I built this by going down to the hardware store, with my ARB bulkhead fitting parts, and finding the correct brass fittings to connect the ARB stuff to a male quick disconnect that fits my female quick disconnect on my air hose.
After a bench test, checking for air leaks, and fixing any if you have them, it is time to reinstall the diff. This is the reverse of the removal, so I won’t detail it here.
Here are a couple of shots of my airline routing.
Compressor,
Above the frame.
what to do if your compressor fails? :D
AxleIke
And done!
Three magic switches
Electric blue hose
I hope that this has been somewhat informative. Please post up and ask questions if things aren’t clear. Thanks!
AxleIke
My rear Bumper Build
Again, copied and pasted, so Sorry for the weirdness.
As many of you know, I had a "not so well welded" bumper on my truck at CM06. Being low on fundage at the time, (mostly due to transfer case gears and air lockers) I re-welded my old bumper to serve until i got the time and motivation to build a new rear bumper.
This is Phase 1. Basically structure. Some cosmetic grinding, but mostly just tacking, fitting, and solid-welding the whole thing.
I'm reusing my old trailer hitch brackets. They are 1/4 plate, and already custom cut and drilled to my frame. Plus, they have been super reinforced.
The main beam, lower wing plates, and forward brackets are all 3/16. The top wing tubes are 1/8 because i couldn't find 3/16 in the size tube I wanted. I'm confident it is strong enough. The tabs going to the frame brackets on the bumper are 3/8" uneven angle. Again, I wanted 3x6, and that was the thinest I could get.
The frame brackets are held on with 4, 1/2" G8 bolts, the bumper is held onto the frame brackets with 4 more, and the front wing support is bolted with the same.
I'm *hoping* I won't have any further embarrassing bumper issues. We'll see.
On to the pictures.
__________________________________________________
A DIY bumper kit? :D
Lining up the main beam. This was the most time consuming part. Measure, move, remeasure, move, measure, adjust...ad nauseum.
Finally got it straight. I also trimmed off the corners.
Tacked on the upper part of the wings...
Measuring for the wing-to-frame support, this table is pretty handy.
All tacked up, ready for welding. I bolted everything together to hold the bumper rigid to avoid warping. I also went VEERRRRYYYY SLLLOOWWWWLY to the point of irritation on my part. But, no warpage was worth it.
AxleIke
got scout?
Phase 1 complete....Fully welded.
Phase 2 will be adding the receiver hitch (recovery), as well as the cosmetic welding. Phase 3 will be tail light hoops, and paint.
AxleIke
Phase 2
Nice enough day, though my toes still froze even with two pair of socks.
Got the hitch hole cut, the hitch tube drilled, with a minor hicup. Welded fully, with AWESOME penetration. The hicup occurred when I was super stupid, and bought the wrong sized drill bit, the bit I bought being too small. So, after much walleyeing, the pin will now slide into the hitch with zero issues. It was frustrating though, since the drill almost ripped my hands off on more than one occasion.
I also got the corners lopped off at a 45 deg angle, and capped, though there was some issue with grinding too much off on the driver side, so now I have a little dimple. :mad: Gotta fill it still.
I ground everything pretty smooth, and got the tops of the mounting tabs ground so my cosmetic strip (fills the gap between the tailgate and the bumper) will fit properly.
On to the pics! Sorry there aren't many of the various steps. I was under a pretty good crunch to get this done before the sun set. Normally, I keep the camera outside with me, and I can snap a few here and there, but it was cold enough that the camera kept telling me the batteries were dead, even though they were brand new, so I had to keep it inside. I was only able to get a couple.
__________________________________________________________
Cutting the hitch hole
Leveling the hitch out.
Welded in front and back. Front pictured
Finished with phase 2. Sitting on garage floor waiting to be loaded for the trip to Boulder.
Close up of front of hitch.
Corners cut. Purely cosmetic, but I was trying to make it look a LITTLE less like a box.
Backside of the hitch.
AxleIke
Phase 3
Essentially all i did was add trim and make an attempt at some "cool" gussets. A design flaw meant that no trim was added on the main beam, but I actually kind of like the look still.
I'm getting this thing coated flat black, which hopefully will hide some of my more salient screw ups. Mostly the scalloping of the grinder.
Thanks for watching! :thumb:
Trim added, shot of the hoops
overall bumper
Passenger hoop
And the finished product. Sorry no driver side pics, but the truck was pulled in funny and it was snowing like the dickens outside.
Corey
OverCamping Specialist
Yo, Issac, nice to see ya here.
Yes, this site is great.
I dig it for all the camping/expedition stuff.
Clemtiger84
