Back at 4x4, 313CDI 4x4 Sprinter
Which model fridge is it? I belive the factory crimped off line is where they fill from. Shouldn't be hard to fix that, just get it evacuated.
Looking great!
Sent from my SM-G900T using Tapatalk
It`s a Waeco CD30. I figured that out too, should be able to fix it pretty easy.
Built the spare tire carrier today:
Of course there was not a single pice of tubing the right size in my 15tons of steel. So i had to turn some down:
Had to weld the plate to a fixture to turn the flange out of:
Mocked it up:
Tacked on some flatbar that will be boltet to the door:
Welded everthing in:
Drilled the bolt pattern:
Welded it in:
Mounted the carrier:
And the wheel in:
Now i want to build a ladder on that side to, but not sure how.
Yep, that's what I would have done (if I had the knowledge, the machines, the material, and the guts...). Stein, you get more done in a day then I get done in, er, ever!
A bit concerned about your tire carrier, however; can that rear door open with the tire carrier bolted to it? You have the 270 degree hinges, and I just don't see how that's gonna open now.
But, clearly you are smarter than me on this stuff.
Thanks java, that's an awesome idea. :victory:
The door will open, but only 180degrees and not 270, which doesn't matter cause the tire would hit the sidewall either ways.
Went to the scales today cause i needed a dry weight for my new registration as a rv.
Really happy with the weight.
Got all the desired paperwork:
Also got the net spare tire and rim:
Then we started building the next cabinet:
Did also some more insulation:
Tried my new chains today:
They`re a little bit too loose for my liking so i think i`ll shorten the inner ring. Not sure how to do that yet, but i got time until next season..
Then i mounted the freshly painted spare tirre carrier with the brand new spare:
Made some more cabinet doors:
And got some work done on the wardrobe:
Also put down a coat of paint:
By the way, what 4wd drivetrain do you have? Oberaigner? Iglhaut? Something else?
It kills me like you wouldn't believe that we can't get any of that in US... :mad::mad::mad:
OK, the curiosity got me... What are the brackets for? Hanging rock climbing ropes and gear?
I`m going to weld some carabiners to the brackets ,so it`ll look like a climbing route and serve as a wardrobe:
It`s pretty stout too, so i can hang stuff like backpacks on it also.
It`s the factory 4WD option. 2WD standart, push-button 4WD and also a rear locker.
Deputy Dan
