Back at 4x4, 313CDI 4x4 Sprinter
Looks like i got lucky, apart from two days of cleaning everything up...
Made a spacer for the Espar to clear the floor and insulation:
The parts pile keeps growing:
Thanks guys.
So i removed the front bumper and started measuring:
Made some mounts:
Mounted it:
It`s a bit lower than i wanted it but the hood would hit the lights it it`be up higher.
Ausgezeichnet! (One of only a few German words I still remember how to spell)
Is that 10mm steel for the lightbar mount?
Overkill. :cool:
Love watching your builds. :sombrero:
Yes it`s 10mm flat bar. It`s not overkill, otherwise it`d flex under the weight of the high beams.
Remounted the Espar today:
Also bolted down the floor:
Yes. But the air heater will mostly be used to dry clothes and stuff, and to boost up temperature. Main heater will be the hydronic, feeding the hydronic floor heating and a small heat exchanger.
Disassembled the couch today:
Cut the rear:
Fit`s like a glove:
Cut it up front:
This is how it`ll be mounted:
Cut the back plate:
Put the fabric back on :
Placed some insulating tape over the insulation seams:
Here`s how the couch goes in:
In sleeping mode:
I like it:
Thanks, it`s really awesome, i like it a lot.
Didn`t get much done today apart from cutting up some cardboard:
Atleast we got a plan now. Well somehow...
Sorry. :sombrero: When will it be at your place?
So we started with the shower today:
While my father startet building the wood stuff i put in some wire tubes:
And spray foam insulation:
The lower part done:
Then i wired in the bilge pump:
Put some insulation on the wheel well:
And the windows:
My dad making the shower walls:
Put some slots in the back wall to bend it:
Cut the shower pan:
And mounted the drain:
Everything together:
Cutting down the big sheet:
And made the cabinet wall:
any info on the Bilge Pump you used and why you chose that one? Have not seen shower install before so just curious
I bought it off ebay. It`s rated for 600gph. The price was right and it seemed well build to me. Wouldn`t need it with a underfloor grey tank.
I bought some push lock locks but didn`t like the feel of the cheap plastic knobs. So i turned some out of brass:
Also took some vids:
https://youtu.be/Efztt4o7Fl0
Deputy Dan
