Before I pull the trigger...
marathonracer4
Ok so heres one of those questions that you search and search for but never really find the exact answer... so before I get in to deep I have a 03 Taco and will be putting 2.5" of lift up front 2" in the back. Will 33 1050 15 BFG KMs mounted on 15" wheelers type B (4" BS) fit. Also with these lift amounts will the truck be level?
yes, the tires will definitely fit. I have seen this combo a few times. and yes, the truck should be about level. however, everyone's truck is different.
Rattler
Thornton Melon's Kid
You may have to do some plastic inner-fenderwell trimming. I am running 32x11.50 Kumho Road Venture MTs with Wheelr's 15x8s on my '04 Taco DblCab on about the same lift in front and I still get occasional rubbing.
Clark White
I run 33x9.50. I had to do some decent hammering (with a small sledge) to the pinch weld at the rear of the fender, but other wise there should be enough room for the 10.50 (at least I hope, because that's my next tire!). I have had problems with the right side rubbing the frame, even with the 9.50, but I think that is due to alignment problems as the left side has LOTS of clearance off the frame.
Clark
Clemtiger84
