Here are the specs...
2-1/2" sus lift
Make: Toyota Land Cruiser
Model: BJ74V LX
DIMENSIONS
Length: 4,265 mm
Width: 1,690 mm
Height: 1,915 mm
Wheelbase: 2,600 mm
Front Tread: 1,425 mm
Rear Tread: 1,420 mm
Ground Clearance: 185 mm
Seating Capacity: 2 (5) Passengers
Turning Radius: 5.8 m
WEIGHT
Net Weight: 1,870 kg
Gross Weight: 2,380 kg
Payload: 400 (250) kg
ENGINE
Engine Type: Model 13B-T, diesel engine, OHV, Direct-injected Turbo
Cylinders: in-line 4
Bore And Stroke: 102.0 x 105.0 mm
Displacement: 3,431 cc
Compression Ratio: 17.6
Max Net Power: 120 PS (88.26kw)/ 3,400 rpm
Max Net Torque: 29.0 kg-m (284.39N-m)/ 2,000 rpm
Fuel Capacity: 90 litres
