pulltilbroke
Ex USAF truck 29,000 original miles, 350/400/205/D60/14B
http://1stgen.org/viewtopic.php?f=5&t=12084
Here is a lick and stick of his ad on 1stgen
1986 Chevy K30 1 ton 4x4 crew cab, single rear wheels. 29,000 ACTUAL miles, I'm the second owner. The US air force was the first owner. The truck is all original even has the original mufflers which are stamped "use genuine gm parts"! No rust, some hail damage on top of cab, and tops of front fenders. All original GM sheet metal, paint has been patched in some areas, paint is peeling in a few others, I buff the surface rust off of those areas now and again. The frame still has the factory applied tar sealant on it. Overall it is a very presentable truck. Has basic styled aluminum wheels with 95% tread on tires. Does not get driven in snow or salt. 350 4bbl, original dual exhaust truck, ( last year for 1 ton non computer, non catalytic converter), TH400/NP205, Dana 60 front and GM 14 bolt full float rear. Recent brake job and tune up. Newer AC Delco battery, starts pretty good in the cold. New power steering pump. Not perfect but very nice for 26 years old, perfect for Cummins conversion. Truck has power steering, and add on a/c that needs charged. $7000 cash takes it, has clear Nebraska title.
