Build slideshow of my Astrolander
Stroverlander
Yep, the T.Low build slideshow, an inspiration to us all. :sombrero: I've been known to refer back to it for reference, comparison and ideas for my own van from time to time.
Eric, the problem you're describing could be as simple as moisture inside the distributor cap. Check to make sure the distributor is moisture free and spray with contact cleaner. There a couple screens in there that can get clogged and be sure to install a quality cap and rotor with brass terminals as opposed to aluminum. From there, check plug wires and coil, etc. You might already know this going on your fourth van.
T.Low
Thanks again. After 4 years ...oops; gotta call to go change diapers, I'll be back...
Lockwoodjd
