Build Thread- 2003 Red Cross ERV- Rambolance
I installed a Nautilus door for space savings.
The bed/ bunk is mostly done also I incorporated a different approach with one of my cabinets:
Up on the roof I added a deck and swapped the ac for a lower profile unit.
The water tank is in, propane tank installed, and I had the good folks at Atlanta Auto Diesel replace the whole fuel system.
Did you build that sliding cabinet yourself? Thats so cool! What did they do to your fuel system? Ive been thinking of doing a fuel bowl delete and an electric fuel pump for mine
Thanks! My buddy came up with the original idea and I had Technocraft make the cabinet and sourced the slides/ installed everything. Works perfectly.
Apparently there was a coating inside the tank from years of sitting. It was getting somehow sucked into the fuel system and causing blockages. We dropped the tank, had it blasted and re-coated then replaced the lines and pump.
Worked on the van all weekend. Put the trim back on the van- paint came out great. Stripped the rest of the interior and found some really bad wiring work (so many of you have gorgeous wiring... not this one). I even found a 110V wire that had just been cut and left that way... no cap or anything. Its also a big mess of wires under the driver's seat- pics below tell the story. as a result, I'm going to go through all the wiring and get rid of whats not needed.
I acquired the exact same rig recently. How did you go about removing the wiring from the box? Trace everything, then cut?
MOLLYmaz
