maxama10 said:Not saying this will work, it has solved many peoples problems though, the 1 piece tom-woods driveshaft.
From what I read it worked for most, but not all.
I gathered this info from Toyotanation
ntsqd said:Something that isn't often mentioned is that the plane of greatest angles needs to be considered and that both ends be in the same plane, but that this plane is not required to have any particular orientation relative to the ground or chassis centerline.
Ignore for the moment that there are UJ's in the mix and just think of a piece of wire with a bend in it. The plane that the entire wire lays in is the plane that I'm referring to.
Now think of the wire with two bends in it. They must not be bent such that the entire wire can't lay in one plane, but there is no requirement for how this plane is oriented relative to the Earth.
Measuring with a level only gets you so far. If there is any lateral offset in the vehicle (extreme example: centered output transfercase used with an offset output intended axle) then those angles need to be measured as well. The plane of the most extreme angle can then be determined for each end individually and checked that they are co-planar.
I suspect that this is why sometimes what "shouldn't work", does. And what "should work", doesn't. Even though the angles relative to horizontal have been measured, it isn't the total picture.
Thank you! This is a hard thing to put into words. As checked with a level the angles can be the same, but the plane of the actual max angularity (which is not always perpendicular to the ground) may not be the same at both ends of the shaft.slooowr6 said:I think what ntsqd meant is some did make sure the two UJs are parallel to each other BUT did not make sure they are on the same plane. Some happen to be on the same plane so no vibration some are not on the same plane so they feel vibration. Maybe before spend $ check if they are on the same plane.![]()
slooowr6 said:BUT did not make sure they are on the same plane.
To find the accute angle you need both the up/down and the left/right angles. If the vertical angles match AND the horizontal angles match (or are of equal value but opposite sign), then the accute angles will also match and the accute angles are in the same plane. Just having the 4 measurements is good enough unless you're driven to do math-stuff.keezer36 said:I'm not sure what is meant by "the same plane", I'm assuming parallel between the output and input yolks vertically. Or are you also referring to a left/right orientation?
ntsqd said:Take that middle picture and assume that it is the top view rather than the side view. Those top view angles are just as important as the side view angles, yet because they are hard to measure, few actually measure them. Most assume that there are no angles in the top view and for the most part that is probably true. But not always true.
It's the not always true that can bite you. The engine may not actually be centered on the pinion shaft. As viewed from the top it may not even sit in the frame parallel to the chassis centerline.
slooowr6 said:Finally got it!
Overland Hadley, Sorry to hijack your build thread.
