Sweet rig! Where'd you get the cupholders? My truck smells like spilled coffee!
hey burn e,
I tried to chase you down on RR.net... about your rack.. I'll try here.
I'm thinking of that rack also...PLEASE.. may I have the exact rack model? Is your truck SWB or LWB? Leg height? height from rain gutter where the leg sits in the groove to the bottom and top of the rack?
my gutter is 73" off the ground and I have 82" garage door max height so I have to squeeze the rack into that gap.
Why the custom legs do they offer shorter? Would they fit and have the rack clear the RR's roof?
Inquiring minds! Your application looks awesome!
Thanks in advance!
I really like your floor mats. :sombrero: Looks like a great location for the compressor.
cheers
Ok, assuming you are asking for the silver roof rack:
Frontrunner Windcheetha (initially from a D90) so the legs that came along were very long.
The legs here are 16,5 cm (front and end) and 15 cm (center) high, considering the curve of the rain gutter. Very important since most Roofracks will have a even lay out which will put a lot of tension into the roof construction.
From groove of gutter to the top (measured in the center) will give me a height of 23 cm. The clearance between highest point of the roof and roofrack is about 5cm. You shouldn't go much lower since this rack have a certain flex when loaded.
