expeditionswest said:Yes.... and no
Tree straps typically have a higher WLL (Working Load Limit) and are wider to improve purchase on the tree. Tree straps are also designed with minimal stretch. Some high quality tow straps will loose their "snatch" memory if used in winching.
BajaTaco said:Here's a test. Have someone half a tree-saver strap around your thigh and then give it a good tug with the winch. Note the results. Now have them wrap a 2" strap around your thigh several times and have a good tug with the winch. Compare results.
vanguard said:Having said that, if I was buying a tree saving right now it would probably be the one on this page: https://www.expeditionexchange.com/recoverygear/
[/SIZE]
