Carbon Fiber Tacoma Bed Replacement Camper - Build Thread
I know you’re a long way from done, but what do you think you would sell these for if you made them?
I do like it a lot. Although my current camper has the tilted inside as well and I’m actually looking more for the four-wheel camper type, it’s a purely vertical wall for more interior room.
But this is amazingly nice!
As a rough estimate the shell only without interior will likely be in the $35-40k range.
I had debated a lot about the placement of the door for this camper. I really liked the idea of a side entry door, but there's a few negatives about it that I just couldn't get past including head clearance when you enter due to the slanting walls, as well as inhibiting natural flow of the interior layout. I really like that the rear door, in combination with the departure angle, make it so you don't have to duck at all when entering the camper. It also makes it more possible to layout a nice symmetrical and functional interior.
One of the primary reasons to go with a slide in camper or a bed delete camper such as this is that it's much easier to seal the elements out of the habitat compared to working around a tailgate and bed tubs that leak like a sieve.
I designed the door frame to have a large flange that works in conjunction with a bulb seal to seal out the elements.
The door itself is built using two 45 degree support brackets and custom welded inner and outer frame.
In the first picture here you see the outer frame getting bonded to the two panel cutouts after getting sprayed with primer, and in the second main frame is getting bonded to the body of the camper.
Here's a video of the door functioning after getting everything mocked up for the first time.
As you might see in the video I decided on a type of full width waterproof hinge and I'm super happy with it so far as I'll be able to leave the rear door open in the rain without water pooling and dripping through the hinge itself.
Any thought of making it hinge the other way and have steps built into it? Flip it down and be able to walk right inside the camper.
I did consider the concept, but ultimately decided against it. I try to keep my designs as simple as possible with as few moving parts as possible and I didn’t see enough benefit in it. It’s easy enough to add a step in another way. I’ll likely be adding a step to the receiver hitch.
This. Is. Awesome.
Great build, I'm impressed by the level of precision.
Did you always plan to make it a business venture, or did that evolve en process?
This. Is. Awesome.
As with most things I’ve built it usually starts with wanting xy or z thing for myself. Then at some point I inevitably realize the project will cost to much to make sense just for myself and that’s when I justify selling a few of whatever I’m building. But to answer your question, yes, that point was pretty early on in this process.
Anyone going to Overland Expo PNW this weekend? We’ll be there on Sunday with the truck! If you see us come say hi!
Just had a great weekend in Redmond, OR attending the Overland Expo! We camped in the camper with our 7 month old for the first time and she absolutely loved it. Currently the camper has no tent canvas, so we camped with our air mattress down on the floor of the camper and it worked quite well! I have to say I'm very impressed with the thermal resistance on a hot, sunny day.
Getting back to the build. We left off after finishing the fabrication of the rear entry door. After that it was time for a quick test fit to determine placement of the wheel well cut outs.
After that was sorted I built a mold for the desired wheel arch size. This mold was simply built out of stacked mdf which was then coated in epoxy resin, faired, and finished with duratec primer.
When it came time to cut out the wheel wells from he main body of the camper I definitely chose the measure twice, three times, four times method! Here's a short video of one of the wheel arches getting punched out - no going back now!
Once two freshly infused wheel arches were bonded into the camper our next step was prepping for paint!
The necessary body work was completed on the main body of the camper, the door, as well as the lid. I've deliberately skipped past showing my method for building this lid because I will likely be changing how I do it in the future. Here you see the camper, rear door, and lid ready for paint! So exciting to see everything come together!
Stay tuned for the next post about painting and final installation on the truck!
I don't claim to be a professional at auto body, but I have done a small amount of it in the past and with this camper being a prototype I decided to save the money, invest in a few tools, and do it myself. One of those tools is an inflatable paint booth. I can spray high build primer in my shop fairly easily since it applies heavier with fairly little overspray, but two stage paint is a different story so I purchased a relatively cheap inflatable paint booth for the project which I set up just outside of the shop.
Of course as soon as the booth gets set up is when Mother Nature decides it's a good time to rain.
I didn't take many photos during the pain process, but you've seen that before elsewhere. Here's the fully painted camper and lid:
The next step was to fill and seal gaps where the various panels come together or overlap. This ends up being a pain staking process of masking off the area and applying an evenly shaped fillet of adhesive.
Here you can see my seven months pregnant wife helping with this process. She's a dental hygienist, so this kind of detail work is right up her alley. ;)
And here you see the finished product on the back of the camper. It's honestly pretty satisfying peeling the masking to reveal the nice, clean lines.
I then hoisted the camper up in the air and coated the entire underside with a couple heavy coats of truck bed liner. This was the last part of the auto body work that needed to be done before the camper was ready to install on the truck. Overall I'm quite happy with how it turned out! Next up: mounting and testing the camper!
My good friend Isaac who helped me build the molds for this camper got married last September and I made it my goal to get to his wedding in BC Canada with the camper on the truck. So here's some photos of the final push of getting the camper mounted to the truck.
I know some of you will be interested in how the camper mounts to the truck so here's what I came up with. Frame flex in these trucks is a definite issue so to isolate the camper from the truck I used three steel cross members attached to the factory bed mount points. These cross members then each had two polyurethane bushings installed in a strategic triangular pattern. As you can see the two forward most bushings were mounted wider than the factory mount points and the middle and rear bushings get progressively closer to each other. My theory on this is to mimic a three point torsion isolating subframe in that the front is kept stable while the rear of the frame is allowed to pivot under the camper. So far this system seems to be working beautifully and I'll show an example at the end here.
The camper was positioned carefully over top of the bushings and then plated and through bolted through the floor.
Here's a short video as we see for the first time how the fully painted camper will look on our truck!
And here's the first time this camper saw the light of day fully mounted and ready for testing. This was finished in a matter of hours before we needed to leave for our Canada trip and nerves were high hoping everything would work out well, but I must say it performed beautifully!
First rest stop on the way to the great north!
On this trip we got the opportunity to do a small amount of off-roading and here's where you can see this subframe system performing. As you can see in this photo the truck's suspension is fully flexed out. You can see the amount of movement the frame is allowed under the camper by noting the distance from the temporary aluminum angle piece the lights are attached to (hard mounted to the frame) and the bottom of the camper. Here's a short video of comparing these two sides when fully flexed.
And there you have it! The camper is on the truck and in process of testing! Let me know what you all think! Would you rock one of these on your Tacoma?
2eleven
