Redline
Likes to Drive and Ride
Time to give these tires a thread of their own. I don't have much to share yet, as I only have a few hundred miles on them and very few off-highway. In the coming months they will see some on-road and off-highway trips. I don't expect any surprises, obviously they won't be 'awesome' if the snow or mud it too deep or wet, not as good as my Maxxis Bighorns (retired on my F350). Though they should do as well or better than most "all terrain" tires. I have read a few negative/neutral comments, but it seems that many owners like the FCII's performance in the winter... we shall see. For me it's a trade off as I prefer a LT255/85R16 but as we know choices are limited in that size.
Below is a link to a thread discussing the FCII and a few other tires, probably helpful to readers seriously considering the ******** Cepek FCII.
http://www.expeditionportal.com/for...4930&highlight=Cooper+S/T+********+Cepek+FCII
To start, a few pics of the new treads, all shot with my iPhone. These are LT285/75R16, load-range-D.
It was not obvious to me when viewing the advertising pictures, but the size of the outer lugs and "DC" sidewall lugs are of a varied size and pattern.
Initial Mounting & Balancing
Used the 'static' (single point, stick-on, tape weight) method of balance.
The tire/wheel combo weighs 83.0-lbs. Tires alone weigh 56-lbs. 56-lbs is less than some heavy 255/85, a bit more than others.
1st mount/balance by Discount Tire where I purchased them. Discount 'matched' a low mail order/online price.
#1 0.50 oz.
#2 3.00
#3 4.50, then rotated 90-degrees on the wheel, got it down to 3.75 oz.
#4 5.25, rotated 90-degrees, down to 3.50 oz.
2nd mount/balance by Les Schwab Tires. After a couple weeks I sold some tires/wheels and removed the FCII from a scuffed set of FJC TRD wheels and put them on a nicer set that have the original PSI sensors installed.
#1 1.75 oz.
#2 3.50
#3 5.50, rotated 180-degrees on wheel, down to 4.50 oz.
#4 5.50 oz. (left this alone because the 'road force' measurement was only 5-lbs)
A couple weeks later I had decided I was going to run this tire for a bit [what does that mean :sombrero: ] and purchased a 5th/spare.
#5 4.00 oz.
Noise, initial impressions.
On my quiet 4Runner, I rate the noise about the same as my Cooper STs in 255/85, maybe a bit quieter. Definitely quieter than the Maxxis Bighorns I removed from duty, but I haven't run a lot of AT tires to compare these too. They actually seemed a bit louder the first few miles, and then slightly quieter, as if the sharp edges on the new tires wore in a bit. Of course it could be my imagination or just getting used to a new tire.
The outer lugs with decent void do have a light 'mud' hum, but tread void is good for traction so there is always a trade off. I look forward to a more pleasant, quieter tire on long highway trips, I'm already enjoying it.
![IMG_0725.jpg](http://i181.photobucket.com/albums/x186/redlineredline/IMG_0725.jpg)
![IMG_0731.jpg](http://i181.photobucket.com/albums/x186/redlineredline/IMG_0731.jpg)
#1 0.50 oz.
#2 3.00
#1 1.75 oz.
#2 3.50
#5 4.00 oz.
