several years ago now but stranded in shiny new Landrover Discovery.
Took three days and much communication with LR in UK to find the fuel cutout valve. It not only cutout but broke internally on a corrugated road. No warning lights, no diagnostics available, not in any available manuals (operating or maintenance). Zilch.
Not as bad but a Ford Falcon auto. Accidentally moved gear to reverse while moving slowly forwards. No indication of why the vehicle wouldn't then start. Disconnect battery trick failed. Industrial systems typically have a "reset" switch.
Really as bad as staring at an ATM that says "transaction not allowed". Little Britain's "computer says no". There are examples of planes falling out of the sky when fly-by-wire gets knotted up.
An early design guide for computer systems was to make things visible. That seems to have been lost somewhere along the way.
Its really a universal problem as computers are used more extensively but designers really haven't got round to designing for what happens when things go wrong. The assumption that the sensor they interpret for one failure mode only indicates that failure mode is fundamentally flawed. And rarely do they allow for sensor failure. Add to that the increasing regulatory environment in developed countries that insist on repairs being carried out by qualified persons, plus manufacturers protecting their information and after sales business, despite education, training and availability not having caught up.
When regulations were introduced to provide diagnostic connections (next to steering column) someone forgot to add that the diagnostics should be available to anyone, and useful.
Even the non-computer models are somewhat flawed, just that the design problem is amplified with the complexity designers can add to computer systems.
A trivial but good example is engine temperature measurement on my Canter. When water level is low the gauge reads low, on the stops. I first thought it was a gauge failure due to a loose connection after rough tracks. Coolant reservoir had visible liquid within limits. When checks of sensor and wiring drew a blank I looked further. At least the fuel gauge fails by reading low!
The fault finding guides in the back of operating and maintenance manuals were never exhaustive or complete. That's been transferred into the computer systems.
Basically, until design catches up with reality (and I'm not holding my breath) simple is good, knowing and understanding the vehicle is good, having a vehicle that can be understood is good.
end of rant!
