Coolers
When on extended boondocking trips, we will use a PopupGizmo ice chest/cooler cover. The cover really does extend the life of your ice!
Note: PopupGizmo will also make custom covers to fit your cooler.
I camp for up to two weeks using coolers and ice, and I always have ice left over when it's time to come home.
For a week or ten day trip, I use an Igloo 160-quart cooler filled with block, and a smaller 60-quart for frozen stuff. I only open the smaller cooler every other day to get out things to defrost. As time goes on, I gradually consolidate the coolers. The procedure for two weeks, up to about 17 days, is the same, but with two 160-quart coolers and about 200 lb of ice total, mostly block, but some cube to fill gaps.
I have plenty of ice for chilling beer, making drinks, whatever.
Next time, I am going to try dry ice in my frozen-food cooler to see how it goes.
I have the coleman xtreme. Says it's good for 5 days, but I haven't used it past 3. I cover the bottom with a couple inch layer of ice cubes, then insert frozen ice packs(the same ones I used in lunch boxes as a kid) around the sides. Then put my food and drinks in, and then pour more ice cubes over and around them. 3 days later the layer of cubes on the bottom was a solid block of ice with all the ice packs. There was still a lot of ice around the food. And of course there was some water that needed to be drained. I was very pleased, as I had opened the cooler probably 20 times during the 70* weekend.
50 QT WHEELED XTREME® 5 COOLER
I still use coolers, and probably will for quite some time. I don't see the need for a fridge yet, I get to take maybe 1 or 2 trips a week long each year, the rest is weekend trips. Worst case is I buy ice once or twice and the labels peel off my beer bottles.
I rented out houseboats for a few years. The Yeti's were still good after 5 years of renter abuse, the coleman and igloo models got replaced each year. I have a Yeti and a Cabelas version of the stainless steel Coleman, both work good. I'll segregate food and drinks from each other if I'm out for more than a weekend since I'm in the beer cooler a lot more than the food.
Just my 2 cents worth. I grew up with a Camper DeVille, a short lived manufacture in Hot Springs Ar, made in the 60s, like an Apachie, but heavier aluminum that opened to one side, anyway, it had a built in cooler, it was about 20 inches deep, 40/42 inches wide and 22/24 inches deep. It was made of tin and 2" of insulation, it was built in to the trailer and the top was plywood with 2" of insulation & metal that inside the inner walls.
We would put dry ice in it before a trip. Probably 5o lbs. It sayed cool for 8 and 10 days! My parents use to rent them in a little camper business and someone rented a trailer and went through Az desert heat and they used dry ice and said it lasted for almost a week.
We did not drain much of the water out. The water was ice cold and kept items cold enough. My mom would put jugs of drinking water in milk cartons. The trick is keeping the ice chest full of items, as we used up food, it was replaced with more food or we put additional milk cartons full of water in there. Another thing is that we used plastic (tupperware) containers keeping items dry. We used a smaller cooler for my drinks as a kid I was always getting into it, so that limited the big coller being opened, but not like we didn't use it. Keeping a coller or ref. or a freezer full of something makes it work less. I keepwater in milk jugs in the freezer in the garage to keepit from running all the time....it's just a big ice box. Keeps dead space out and items stay cooler.
I will be looking for a new cooler soon, I have been using plastic cheap ones for the boat forthe afternoon. I see the refrigerators posted here for $600 and up and seems nuts to me, since I think of that old built in coller in the Deville. I have not tried buying dry ice lately, so I don't know if you can even get it anymore, but if it is still readily available, I'll be going that route without power drains, break downs and limited storage space. Now, if I were in a motorhome, that's different.
Aluminum box as the form and the garbage bag (doubled up) is filled with approximately 20L of ice and frozen in the deep freeze. 20L of ice is then put in the bottom of a 5 day Coleman 59L cooler. We get a week out of it for our food and beverage cooler, usually have extra ice left over...so every trip we've been making a smaller and smaller block of ice.
As for dumping the melted ice, the water is cold so why dump it and displace that volume with warm/hot ambient air? I don't drain my cooler and make sure anything in the cooler is waterproof, just one of the major drawbacks to not having a $$$ fridge. Or you could drain the water but offset it by freezing more ice, or freezing them in a plastic milk jug or water bottles (we will be trying this route this year).
I have used Coleman steel and stainless steel for many years, my current Stainless cooler is very good. The SS is easy to ding but looks are not a big deal, a good choice for sure. I also use two Extreme Coleman coolers for 5 days every summer and side by side they give about 1 day more. Both full of block and bag ice with a moving blanket for shade......
Deputy Dan
