D.O.A - 89 Chevy Ambo Build
Looks good, with good height and coverage! That is pretty much what I need for mine, but I want to put it on the right or patio side, which will also be my kitchen side.
Once you fold in the support poles, does it roll up somehow for storage back in the bag? I'm guessing it's all manual and you need to use a ladder to deploy or store it, right?
Yeah, Totally manual, It does roll up into the bag, Deploying or storing can be done without a ladder, but you need two people, One on the roof and one on the ground, alternatively One person can do it with a 3 step stool. I need to find one that will fit in the Backboard slot..
I want mine to run full length like yours, so the only way I'm going to get it to clear all the lights and the door is to do it just like you did yours. I may end up with a rack on top for solar panels, but mounting it on the side of that still leaves a gap between the body and the awning for rain to run down in between.
Do you happen to know the brand and model number of the one you have? That would give me a place to start looking.
It was originally on a Forest River pop up camper. I'm pretty sure it is actually a Dometic Trimline 12'x7' bag awning;
http://www.dyersonline.com/dometic-...lJIKdlsqh8gQ-vxnpwtikqMTBkZdrxlIvjxoC76Hw_wcB
Yeah, I Looked at putting it on the side, and it would have had to go below the markers on the top, which would have put it into the gutter on the side, and it would have covered the scene lights partially, Plus the doors for both the front and rear compartments would have been really hard to open and close when the awning was in the bag.
In the end, the best solution seemed to be the way I did it, which is with the rail about 7" in from the edge, so the bag stays on the roof. There is still plenty of room on the roof for Solar Panels, though that will force deploying/storing of the awning to be done from the ground..
With your Wheeled Coach corner markers, you might be able to get away with getting closer to the edge, and since you're setup as a trailer, are you even required to have the marker remain visible? You might be able to put yours all the way at the edge...
Yep, that is the same problems I ran into which is why I like the way you did it. And yes, the markers are required because it is over 80" wide as per FMVSS/CMVSS/ 108.
I read the specs on that awning, and it says it's only 7' wide from the vehicle to the outer edge. Is that right, because yours sure looks lot bigger than that? Ideally, I would like to have a 10' x 12' awning or at least a 8' x 12' one, so you have room to sit under it in lawn chairs and still move around. Any rain coming down at an angle will reduce that 7' to about 5' of coverage.
That's correct, This awning is just a hair over 7' from the rail to the edge, With the overhanging piece in the front, I think it will really give about 6 feet of rain/weather protection depending on wind conditions, and it will also depend on how much you pitch it down, I think if you pitch it down more it will provide better wind/rain protection, but you sacrifice some of your view and the ability to walk straight out from under it going forward...
Carefree of Colorado is the other big manufacturer of Bag Awnings like this, and they have an 8' extension model, but their's cost 3 times as much as the Dometic's
https://www.e-carefree.com/ecarefree30/cfg?pid=79&action=cfg
I haven't looked at any other manufacturers yet...
OK, so I Was searching for an awning for the patio side today, and found that I'm wrong about the brand of the current awning, it's a "Shademaker Classic" not a "Dometic Trim Line"...
Not much difference there except there seem to be fewer dealers... It's still a 12' wide x 7' extension. and costs a little more than the Dometic's.
All the bag awnings I looked at were 7' extension, I didn't see any that came out more...
Thanks for the info John, and I have saved all of these links. When the time comes, I'll go through everything I have and figure out which is the best route to go.
Did my first Scene Light conversion to LED tonight.
I Used These Lights;
Luyed LEDs
Partially disassembled Whelen Scene light;
I unbent the leads on the Halogen bulbs in the light, and carefully removed them from the reflector. Once the bulbs were out, I used a 3/32nds drill bit to enlarge the lead holes to accept insulated 16 gauge wire.
I cut some pieces of Blue and Orange wire (It's what I had around) about 4" long, and stripped about 1/4" at each end.
There are no markings I could find on the LEDs for positive and negative, so the next step was to figure out the leads, I did that using a harbor freight battery trickle charger. Once I did that, I soldered the wires to the appropriate leads on the bulbs.
I then fed the wires through the holes, and pulled them through until the bulbs were seated in the sockets. Then I bent the wires in to the wire slots on the back of the reflector.
I repeated the process for the other bulb, and stripped the original whelen light connector, then soldered all the leads together. I then put heat shrink on the soldered connections.
At this point I bench tested the light to make sure all my connections were good;
After making sure all my wiring was good, I hot glued down all my wiring;
I then reinstalled the light into the original housing on D.O.A., I also took this opportunity to replace the factory screws in the housing with #10 x 1" Stainless Steel sheetmetal screws.
And here is the result;
The light closest to the camera is the new LED setup, while the further light is the original halogen. In my shop, it looks like the LEDs are not as bright, but still plenty bright for lighting the area under the Awning, , I think that will be fine since I won't be working scenes 200 yards from the Ambo. This reduces the power consumption from 54 watts to 3 watts per scene light fixture, and I won't be worried about melting my awning with them.
Total cost for the conversion is $2 per fixture for bulbs, plus solder, heat shrink, glue and wire.
Some photos from recent upgrades, and last weekend camping. I've been pretty busy this season being a guide at three different off-road parks, and fixing the crawlers between weekends wheeling, but I've managed to add a few things in between those, just haven't found the time to update the thread with the updates...
Added a TV and Blu-Ray;
Put a smaller awning on the porch side, this one is a Shademaker XL, the same brand as the other side, but actually designed to attach to the RV rather than having poles to the ground. (The lower supports are much longer) http://www.shademakerproducts.com/supreme-xl-bag-awning
This is the AC unit while traveling, this is also the location I'm using it from, last weekend I just ran the exhaust through the cab and out the passenger window. this is the location I keep the heater in for cold weather, thankfully the weather in this area isn't extreme, so I can just switch the heat/AC as required.
These are photos from Camping last weekend at The Cove Campground, Gore Virginia, where we were attending the Big Dogs Off Road Spring Fling;
This is the kitchen, everything under this canopy stores in two of the outside cabinets on DOA, it's normally under the awning, but the arrangement this weekend kind of moved it up closer to the cab, total setup time for the kitchen including the awning is about 30 minutes.
And these are the two crawlers I took to the event;
Looks like a fun time! :beer:
It won't stop raining here long enough to work on rigs, much less take them out and enjoy them. :snorkel:
Here Here.... it is irritating as hell. rains every week pretty much and every day it chooses to rain is Sat. my only long day to do things..... and Fri. my only half day to do things.
Up until last week, it's been pretty wet here too, It actually rained like hell here the night before I took those pictures, and has rained at least one day during every event I've been too... But last weekend really turned out to be beautiful both Saturday and Sunday...
Going out again this weekend to Chaos Off Road park in West Virginia, and...
It's supposed to rain Saturday :(
I could not find in prices on those awnings did you have to buy from a distributor?
Do you mind sharing the price
Thanks
Deputy Dan
