rebar
Iv posted this question in another forum without any response so I will try here..
Since the Dana 70U uses the D60 bearings with the only difference being the larger ID on the pinion head bearing bore. And the 70B, you only get the larger pinion head bearing.. But when you compare a D70HD, you get the larger pinion head bearing and the Dana 80 sized carrier bearings.
Its easy to see I would be wasting my time with any axle other than the D70HD or D80 since I own a D60FF already. Im not sure how the wheel bearings changed from each D70 though.
Did any SRW E350's get equipped with the D70HD's or D80's? Or were those only found on dually cutaways before I spend time looking? The problem is that the D70 housing was still listed as a D60 so it has a D60 number. And the same gear cover makes it hard to distinguish from the D60 to someone in a hurry making a personal inspection a necessity.
Thanks
Thanks
