Differentials, adding a full-floater
notmiller
I would recommend Chris' kit. He didn't quite have it yet when I started my swap and it was pretty time consuming piecing it all together and modifying hard lines, etc. The kit will save you a lot of time and headaches.
djm68
Thanks for the tip. So, if I were to buy a complete 2005+ Sterling 10.5" (including brakes) and buy Chris' kit, will I need other parts to adapt this axle to my 09' E350? Clearly, the new spring perches will need to be welded on; but what other parts of mods will need to be performed? I am trying to scope the scale of this project as I'd like to do some of the work myself -- I have quite a bit of experience working on braking systems, but will likely leave the welding to a pro.
Thanks,
DJM
notmiller
Besides spring perches, the shock mounts and brake line tabs (all part of Chris' kit) will need to be welded on. You'll also want the e-brake cables from the donor vehicle as the Sterling cables differ from the van's stock rear cables. I think Chris' e-brake adapter is meant for the Sterling cables, as well. I'm not sure, but I would think the speed sensor connector should plug right up on the pumpkin. At least it did for a 2003 Sterling into a 2003 van. And of course, gearing should match front and rear.
A question for Chris: Does your install kit include the brake line coming down from the frame with the T-block on it? If not, DJM, you will need to get one.
ujoint
Supporting Sponsor
No, the install kit doesn't include that line because it comes in the brake line kit. Not a problem to get one line for jobs like this though.
Lockwoodjd
