Drivers side front end sound help
ccm00tacoma
A strange noise............
A couple weeks ago I had a strange noise develop in the front end drivers side at the wheel (I believe).
It almost sounds like a thin metal scrapping that definately coincides with wheel speed. The odd thing is that it only occurs in one situation. When turning left, at mid to high speed. When turning left slowly (such as making a u-turn) it is silent. But anything that initiates any sort of body roll when turning left produces this scrapping sound.
Yesterday I replaced the CV boots on that side so I was able to get in there and see if there was maybe just a small rock stuck between the disk and the dust cover, but there was not. Everything seemed to be inplace and in alignment. Could this be a wheel bearing issue? It seems odd that it would not make that noise all the time then. Perhaps i'm wrong.
Maybe it just needs an Engel MT-45 on the drivers side to counter-act the body roll?:hehe:
Any insight you guys can provided would be greatly appreciated.
Thanks, Adam
toyrunner95
thats called IFSitus, there is only one remedy, you MUST get rid of the IFS its like an appendix thats about to burst. it could very well kill you.... naaaa im just joshin.
check your breaks, you may be down to the squeelers on your pads. OR there is a little tab that can get bent the wrong way. you wont hear it when you break because it has pressure applied to it. around corners you probably hear it because of the body roll and stress on the system.
it doesnt sound like a bearing noise, usually thats a loud squeel thats constant and you can hear between certain speeds because of our range of hearing. also bearings clunk and creak when you go around corners.
look for any wear on anything if you take the wheel off. like fresh metal scrapings or a bright shiney spot on anything.
Clemtiger84
