Dual Battery necessary?
gravelguy
A question for the expo elite.....I am planning on running a month long trip around the great American West in Oct/Nov. I want to go as light as possible and trying NOT to go dual batteries.
My needs are simple....I will run a waeco cf-35 round the clock and have a dome light in my maggiolina for reading at night. The rest of my battery needs (gps, charging iphone, etc) will take place while driving which I plan to do everyday. My power outlets are hot all the time.
My vehicle is a 2007 Tacoma TRD offroad (more on that later...) with the stock battery and HD alternator that came with the TRD package. So far in testing I have been able to run the waeco for 6 days with minimal driving and never had the low voltage cutoff come into play.
Any input is appreciated!
cruiseroutfit
Really it depends on your driving/idling patterns with the vehicle. If your driving the vehicle on a daily basis or even every other day, you should have no issues. If having the vehicle parked stagnant for days on end is in your trip plans, the reassurance of a backup battery should be investigated. At a minimum I would recommend a dual battery monitor and possibly a low voltage shut-off device if your fridge for example doesn't have one built in.
LandCruiserPhil
I would give strong consideration to solar. It would eliminate the needs for a second battery if you are traveling and give you the needed power if you find yourself in one place for a couple days.
JIMBO
:sombrero:Going SOLAR is RIGHTON
Using a 60 watt Sunpower panel has served my camp/trailer for almost three years, using one lead acid battery for my Engel cooler (even started with a Koolatron cooler)
Using an Engel type cooler-Solar is the way !!
:costumed-smiley-007:safari-rig::safari-rig: JIMBO
soonenough
I'm far from an expert on the subject, but I'd give some thought to the relative level of "need" for dual batteries in relation to the areas you will be traveling in. For instance, if you're never more than 30 minutes from a city/town of reasonable size, maybe it's not worth the investment, since the worst case would be calling a tow truck to come out and give you a jump.
But, if you're planning on being truly in the middle of nowhere (as in, a dead battery will mean a very expensive visit from a tow truck, or even worse a possible rescue scenario if there happened to be a medical issue while the battery was dead), then a dual battery setup might be cheap insurance and offer some peace of mind.
If nothing else, you could look into one of those little battery jumper boxes that you charge at home and take with you. Then, every time you come into a town to make a stop, try to 'borrow' a wall outlet to top off the jumper box if necessary. That would definitely be way cheaper than a dual battery setup. One of my previous cars had a weak battery, and I carried one of those with me everywhere I went. I was far from diligent about making sure it was always topped off, but it worked perfectly the 4 or 5 times I needed it (and it wasn't an expensive one either).
Superu
Is the stock battery a dual purpose or will you be draining your standard starting battery every night? At the very least, I would suggest upgrading to an AGM Dual Purpose battery if you're not going to run duals.
Corey
OverCamping Specialist
spikemd
I agree with the portable power pack. They have ones that will charge being plugged into the 12v while driving. The units are a lot cheaper than a dual battery set-up.
I would also consider upgrading your 'stock' battery to a larger deep cycle or AGM battery if/when it dies on you.
http://www.windsun.com/Batteries/Battery_FAQ.htm
Today, I bought a Powerstation from Costco $65 with 18Ah battery to 400amp boost, 1000amp peak and measly air compressor/dc outlet.
I also saw the Duracell/Xantrex 600 unit that has dc outlets/ac outlets/jumper cables and 28ah AGM battery for $140 on Amazon. I may get that one instead and return the Powerstation.
I want it for backup and/or running a fridge at night.
I was also thinking that a powerstation can be mobile and taken into the tent to run a fridge, therefore not tethered to the truck.
Mr. Leary
Glamping Excursionaire
I carry a jumper pack with an air compressor. Its slow, but it gets the job done. It serves as a good backup for on board air and dual battery setup, and doesn't weigh very much. Generally, I beleive in mutually supporting systems with built in redundancies. Strategy has never let me down so far. I would wager that the fact that you even asked the question means that you should buy it, cuz if you don't, you WILL worry about it on the trip.
Cabrito
I come in Peace
I just recently got a used ARB / Engle MT35. I ran it 24/7 last week while in Yosemite. It never drained my battery overnight. I also carry a battery pack to jump start if needed. By the way, I ran the fridge off the battery pack for 14 hours as a test and it still had plenty of juice left. The battery pack I got at harbor freight and has a 24ah battery in it. It's beefy.
OldSven
Not sure if it was disscused or not but weather plays a factor. On our camping trip over the weekend I had the Norcold cranked up like normal but it was about 30 degrees at night and the red top actually sounded pretty weak when trying to start it in the morning. It is always nice knowing that you can just kick on the second one and off you go:)
Switch
If you going to be in areas so remote that you cannot get a jump start, then it makes sense to have some kind of backup. A built in dual battery is only one option and spendy at that. For just one trip, it does not seem worth it to me.
Dave Bennett
Adventurist
Carry a jumper pack at a minimum, they are well worth having. For bigger trips over many days dual batteries with solar is the hot ticket.
Or, 'wheel with a buddy ;)
RHINO
tacomas have a battery fail safe built in and wont let the batt drop below 10.7v or something like that, even if you leave the door open and radio on it will shut everything off before the battery gets too low to start the truck.
you have to put some faith in it,,, but it works on mine as tested in the garage.
solar doesnt have a downside per se, but, w/o charge at night you do need to make sure you can store enough power for everything you need.
dhuss
