E-Locker Harness wires ripped out.
Grim Reaper
Paul R said:
That would definately solve your problem and work great if all else fails, I picked one up at the stealership.
We will call it a draw. I was editing my post to put that bit in and when I posted it you had posted almost the same time. :)
AndrewP
Those pins are available new from Toyota, and it's much nicer to install a new pin and solder the wires, rather than try to undo the crimps and re crimp it. I am pretty sure that nearly all their pin connects (there are at least 6 different ones) are available. I even have a few for a rear sup tank harness around here somewhere that look just like those!
p1michaud
Pin part numbers?
Do you have a part number for them? I've tried to purchase just the pins in the past with no success.
Cheers :beer:,
P
AndrewP
Cheers :beer:,
P
I will have numbers for the sub tank harness pins.
Call Cruiserdan at American Toyota and he can match these easily from the pic and send them out. What I've received is the pin crimped to about a 6 inch length of wire.
p1michaud
Replacement pins
I don't need any right at this moment but this is good information to have in the back of your brain. Thanks!
:victory:
iStan814
