Engel 43 or 34 QT ?
Purchased those before the tie downs just need to find some with double hook ends that are longer than the ones I purchased, as well as make some tabs for them to mount in like the engel setup.
Aaron
Search "turnbuckles" at McMaster-Carr. Personally I'd go with the clevis type rather than those with hooks. If you need/want QD then replace the upper pins with "Quick Release Pins", also a MMC search .
Aaron,
Great ingenuity! I agree with moving to turn-buckles instead of the straps, but I think you did a great job.
By the way, what is that light bar inside the back for?
Pete
mountainpete said:
Aaron,
Pete
I will have to get the turnies when I get back from Tellico. The strobes are for work. My company does road work from traffic signs to installing miles upon miles of Safety Barrier system (guard rail). IN FL cross over accidents are responsible for to many fatalities.
Aaron
Engle 43 or 34 qt
I am in the market for another fridge to compliment my ARB 43. I am looking at the Engle 14 or 16. I would like something I can use on day trips as well as longer trips with my 43. Any suggestions? Also who do you think has the best prices?
Mike El Paso TLCA 8009
1985 FJ-60
1977 FJ-40
Pictures http://community.webshots.com/user/mep1811
You could try flyingwil who is a member here on ExPO and at Sierra Expeditions .
.....Tucker
Whoknows said:
Anyone know if it is possible to buy just the tabs and turnbuckles?
Yeah you might have to make them, I did notice while at the hardware store the mirror hanger look very similar to the tabs used for the turn buckles.
Aaron
DIY Fridge Slide
xcmountain80 said:
Ok so I got the fridge slide done and will install it tomorrow.
Aaron,
Very well done on the design and build of the slide. Could you put together a parts/price list for your materials when you get the chance?
Cheers,
P
FYI: I was in Wal Mart today and ran across a nice small wireless thermometer unit, just under $10, compact, no danged clock, no Celsius display, 100' range, uses AAA batteries
ACCURITE00782
Product Description:
Simple, easy-to-read, and accurate, this wireless indoor/outdoor thermometer displays temperature readings taken by its remote sensor located up to 100 feet away. No time, date, or any other digits to fish through, this compact and uncomplicated thermometer displays Fahrenheit temperature only in large, easy-to-read digits.
If you're only interested in the indoor and outdoor temperature, this is the perfect wireless thermometer. It's compact and reports only temperature in nice large easy to read numbers.
Features:
Main unit measures 2.75" X 2.5"
sensor measures 2" X 2.5" X 1"
Displays indoor and outdoor Fahrenheit temperature simultaneously
Wireless indoor/outdoor electronic thermometer with remote sensor
Simple design displays Fahrenheit only
Wireless technology receives temperature data from remote sensor
So far so good on the tests. In ambient temps the unit's two displays are within 0.2 degrees. The wireless unit updates more slowly, possibly when the temp changes rather than a fixed time update from what I can tell. Probably to save the batteries. I am running it side-by-side with my Engel thermometer in the fridge and will post up later.
Bobbyjr
