eXpeditionXterra Build Up
On the transmission cooler, did you leave the fan as a puller or did you reverse the polarity to a pusher? Just curious.
Pretty amazing. When are you going to swap to a Cummins 4BT turbo diesel? Can't be much else left to do.. (-:}
Not saying anything new here, but totally agree x100 with all the comments on here about how sick your rig is.
Seriously, what do you do that allows you to do all these sick but expensive upgrades, let alone the time to get it done? Whatever it is, I want in! : )
Then again, I definitely don't have the know how to put it all together since I'm an electrical idiot and just slightly better in a few other mechanical areas.
I wish we had more open terrain to explore in the Northeast like you do out in the desert...man I miss living out in Utah!
Again, truly amazing build. Keep it up and the pics coming! Total inspiration man!
A few more
Replaced the cracking front cross member, and designed a new front plate to compliment the solid axle. The designs weren't just for looks, I wanted good ventilation for an oil cooler install.
Also, we are finalizing the rear end with 2.0 fox piggy back shocks, and integrated in to the rear shock tower/crossmembers is the aux fuel tank.
Finally a side view.. sitting a little high, unloaded. But new rubber 35" toyo MTs!
No rear shocks or aux tank in yet, so she may be sitting lower when those are in.
Bobbyjr
