FG84 Workshop Manual
bptp7270
Sorry I didn't see this at the time of the OP.
If you are still looking to open up the dash to swap the radio, photos of the process are here:
http://www.hackneys.com/mitsu/photos/buildup_album_22/index2.htm
Hi there,
I assume that the cig lighter cover is removed with a small screwdriver or like to reveal a screw that retains the larger radio surround. Once removed I guess that the larger section can then be popped out of place. They are excellent photo's. I was hoping to have a go at it this week.
Thanks, Anthony
dhackney
Hi there,
yes, that is correct
Yes. IIRC, it pops off, but be sure to look for screws first. I haven't done this since the last time we shipped the truck two years ago.
I do this every time we ship to strip the cab of all the radios, etc. It only takes a few minutes once you are familiar with the process. Allow 10-15 minutes the first time. Take your time and look around. Between the manual and the photos, you should have no issues.
Thankfully, the entire dash / cab is easy to disassemble for a non-professional mechanic like myself. :)
If you've got the time, an excellent upgrade of the cab is to remove the seats, headliner and floor mat and line the cab with acoustic mat. It quiets the cab significantly and also reduces the load on the air conditioner a bit.
You can strip the cab in an hour or two.
The only tricky bit is the snap-pin connectors that are used to hold some of the interior trim pieces. You'll need a pry bar about 20cm long for some of those. We took an old flatblade screwdriver and cut a V notch in the end and bent the end to about a 10 degree angle. It made a perfect tool for the job.
If you are mounting additional speakers, you'll have the cab stripped out anyway, so that is a perfect time to line it with acoustic mat.
It's also the perfect time to install & route cables for map lights, 12/24VDC power distribution, radio antennas, GPS antennas, satellite phone antennas, etc.
If you want to go all-out on the sound system, it is possible to do in the FG cab. We mounted high-quality replacement speakers/drivers in the door, smaller diameter speakers/drivers in the upper rear corners of the cab and also put a big subwoofer in our center console. The controller & GPS for the head end and the power amp mounted in the base of the console hidden by a false floor (controller & GPS) and in a side compartment of the console (power amp). The iPod mounted via velcro in the center console. The system was spec'ed and initially installed by a friend of a friend who installed sound systems in ski boats. The system sounds great, but it was overkill for us, since we don't do a lot of high-volume rockin' anymore.
In addition, I needed to re-wire every single thing the kid did. Lesson: You'll be better off doing your own work than letting someone do it who is accustomed to doing street vehicle installs. Do not use cheap connectors. We used marine grade crimp/heat-shrink adhesive connectors for all of our wiring. Expensive, but they stay connected in off-road / overlanding use.
You will find photos of all of those installs, parts, etc. in the buildup photo albums.
Air seats: album 7 & 8
Stripped cab, acoustic mat: album 17 & 18
Console: album 21
Factory dash switches: 21
Pass-through fitting for cab antennas: 21
Cab wiring for radios, etc.: 21
Cab radio install: 22
Stripped cab: 22
Album 17: http://www.hackneys.com/mitsu/photos/buildup_album_17/index.htm
Album 18: http://www.hackneys.com/mitsu/photos/buildup_album_18/index.htm
Album 21: http://www.hackneys.com/mitsu/photos/buildup_album_21/index.htm
Album 22: http://www.hackneys.com/mitsu/photos/buildup_album_22/index.htm
Buildup site is here: http://www.hackneys.com/mitsu/
This build will look pretty amateurish by your OZ standards. Had I known at the time ATW and the other FG builders existed down there, we would have just shipped our chassis to OZ and had them install one of their proven camper boxes on it. As we say up here: Live and learn. :)
Example of the marine Ancor Adhesive Lined Heat Shrink Connectors we used in the build are here:
http://www.wholesalemarine.com/p/ANC-309003/
whatcharterboat
Now I can pull my dash apart to replace the radio without breaking anything.
Anthony,
Maybe you've already got this far but can I just add something that may not be so obvious when you are doing it. It's the demister controls below the audio unit............disconnect the cables down at the demister rather than try to get them off the control panel. Then push the cables back up through the hole still attached to the panel as you remove it. You'll probably have to drop the controls down to the bottom location if you intend to fit a double DIN head unit above.
Sorry....we got off track before and I neglected to tell you this.
How good are Doug's pics?
bptp7270
Hi John,
I was bored this afternoon so I decided to have a go at the radio removal. A scary prospect in light of my aformentioned opinion on the delicate nature of the plastic on these things. Anyway, using your previous tips, the wokshop manual and Doug Hackney's excellent photos, the complete removal only took about 10 minutes. What an anti climax. The hardest bit was pulling the entire unit forward far enough to extricate the radio, due to the short wiring harness connected to the heater controls. The clarity of Doug Hackney's photo's removed any fear I had about giving that lump of surround plastic the tug required to remove it. On the 649 I had to remove the passenger half of the dash to get the radio out. Although the materials look very similar to the 649, the assembly process is much simpler on this model A good tip in the workshop manual was to tie some thin wire to the two heater cables once removed, to enable you to drag them back down if they get lost. I moved the heater control down to the bottom slot so I can get a double din unit in above it. Now I just have to get a unit that fits and the adapter plug for the factory socket.
Anthony
PNWav
