Fitted sheet for Autohome Medium mattress?
chmura
I purchased a new Medium Autohome Extreme tent.
What are people using for a fitted sheet that fits around the mattress?
The size is Mattress: 54″ x 72″ x 3.2″.
I did a quick search in this sub-forum and did not come up with many posts on this topic.
INSAYN
I use a "full" size mattress set of sheets. With the cut outs on all 4 corners of my Maggiolina Airtop for the lift arms, the sheet has more than enough excess material to cover and tuck in around the entire Autohome mattress even with a 1.5" cut to fit memory foam topper added.
chmura
Thank you I will give they a try.
I was thinking about adding a layer of memory foam as well. Where does one buy a 54x72 size memory foam?
Dozer Dan
I have a 2" memory foam layer over the standard mattress. Just get basic memory foam and cut it to size and any cutouts you may need.
I also use sheet straps to keep the fitted sheet tight. Similar to these. I use 2 pairs I got from ebay.
ORIGINAL-Sheet-Suspenders-gripper-fastener-straps-featured-on-QVC-Keep-all-sheets-smooth-and-tight-S__41K0Hi3tpjL.jpg
chmura
Very good idea I might consider doing the same with the two straps. Thank you.
jennajamieson
Fitted sheets often have elasticNavy blue sewn into each one of the four corners to help it stay in place over the mattress. Fitted sheets protect the mattress and provide a comfortable surface for the sleeper to lie on. You can either use a queen size flat sheet on a double bed or vice versa.
Westy
Fitted full size sheet is an excellent choice to fit the medium size mattress of the Autohome tent. It works quite well, dimensions are nearly exact to a full size mattress except of course the depth but folded under and with the elasticity it stays in place well.
Corey
OverCamping Specialist
I have the medium AirLander, I am using flannel full size sheets with the bottom one a fitted one.
Also using a winter wight down comforter in a full size.
Both work out great.
Beowulf
What has everyone done with the Small version? It looks like the Full XL sheet sets would be the closest.
Pappy
I took an old queen sized flannel comforter cover, sewed it down to size, cut off the excess, and slipped it over the factory foam. I also have cheap 1" memory foam from Walmart underneath the factory foam mattress, cut down to size.
mbauerus1
