p1michaud
Scott has started working on this mod for the Arctic Ocean Expedition but I thought it would be a great topic for other folks who would like to run winter trails with snow chains.
I want to explore my options for fitting tire chains. Here is some background:
Known modifications:
My know options to gain clearance as this time are:
Here are the questions I have:
At this time, I’m leaning heavily towards the RUD 4x4 Grip Chains mainly for ease of installation based on the reading I’ve done to date and what I saw on Bill Burke’s “Getting UNStuck”.
Cheers :beer:,
P
- My truck is a 1999 Extra Cab Tacoma, 4x4
- I’m running 1.5” to 1.75” OME lift front and 2” Deaver Springs lift rear.
- My tires are 32” x 11.5” Good Year MTR on stock 15” x 7” alloy wheels. I believe that the stock off set for these wheels is 4.5”. Is that correct? I’ll have to remove one and measure it to be sure. This tire and wheel combo does not leave sufficient room for tire chains mainly due to the distance between tire and upper control arm (approximately 0.5” to 0.75” in my case).
- My know areas of concern at this time with respect to clearance (without having actually test fitted the chains) are the frame, sway bar and upper control arms. These are all in relation to the front wheels since I feel that my rear wheels have sufficient clearance at this point.
- Remove my “shortened” mud flaps. The tires occasionally rub on these when turning so I know that they will be in the way. I keep them on to keep the road salt and sand off the truck. Only a concern during the winter months but can easily be removed during winder outings to gain clearance. Side note here, how do you guys that have removed your front mud flaps keep dirt and mud out from that area between the outer fender and truck body free from debris (i.e. if you open your driver or passenger door and look down toward the bottom of the door towards the front wheel well there is a small opening that seems to fill with mud. I’ll take pictures tonight for clarity)?
- Pinch weld mod
- Wheel Spacers (1.25” minimum)
- New wheels with different off set (not sure I can get enough clearance via this route).
- How much clearance do you need between suspension components and frame to safely operate your vehicle with chains on. Is 0.5” sufficient?
- What other options are there without busting out the grinder and reciprocating saw to increase clearance? :Mechanic:
- Have I missed something?
Cheers :beer:,
P
