FJ60 Must-do Reliability Modifications?
stonepa
The only issue I have ever had in my 25 years with the FJ60 is the manual choke cable. That thing has stuck / collapsed / god only knows what too many times to count. That being said, I've never been stranded.
NM-Frontier
X2 what 1911 was said with the plug. Other then that just say up on your maintenance and drive that sucker, 119k is nothing for a Cruiser. Don't worry about a desmog unless part that system fails on you, then maybe look in to it. For now just use you time and money on driving and enjoying.:sombrero:
cruiseroutfit
Failures I can think of: Oil galley plug, tie-rod ends and more importantly drag-link ends (if excessively worn they can pop out of the joint), u-joints, transmission to t-case seal, seized bell-cranks, loose pinion bearings, worn cross-shaft in rear diff. More if I think deep but really all those are easy to spot and remedy. 60's are tanks!
gregnash
Think most things have been touched on.. Only other thing I would look at would be to check all your ground connections and make sure they are nice and tight and possibly go through a brake job.
NMC_EXP
Good point about the grounds - thanks.
Regards
Jim
dhuss
