Martinjmpr
Wiffleball Batter
Last year I put together a solar setup using a Renogy 100w panel and an MPPT controller. I only used it twice because it was a little bit cumbersome, the worst part being the transporting of the panel itself, which was the big, rigid 100w panel of the type you typically see on houses.
I was thinking that putting my own system together would be cheaper than buying a self contained unit.
Well, I was wrong. Transporting that panel without damaging it turns out to be enough of a PITA that I typically leave it at home.
At this point, I'm ready to chuck my current setup and get something portable. I know Renogy makes a 100w "suitcase" panel and I believe it has the built in PWM charger. Are there any others out there that people have used and can recommend? At first I was thinking of just getting a folding panel and using my existing MPPT controller but I think a fully self contained unit would be smaller and simpler, which means it would be more likely to get used. Trying to stay under $300.
Also if there's anybody out there on the Front Range of Colorad (Fort Collins to Pueblo) who wants to buy a Renogy 100w panel and 20a MPPT controller (only used twice), PM me. I'll cut you a deal. :sombrero:
