roninjiro
For Sale or Trade/Partial Trade: 2003 Nissan Xterra Turbo Diesel (se trim)
Description: 4wd Xterra with:
TD27T Turbo diesel conversion completed with around 8k miles on the swap (all metal fabricated together was TIG welded)
Mechanically injected (tune as you please, currently boosting 20psi)
3" AC arctiulator suspension lift
Front and rear Shrockworks bumpers
No dents in the body/bumpers/undercarriage (except replaced driver fender there is a small dent near the headlight)
A/C blows cold
New dual core radiator
New external transmission cooler
New water pump
New belts
New fully custom 2.5" exhaust (done by me and TIG welded together)
SE Trim
Bragging rights/trail worthy/streetable
This is my daily driver 30 miles a day so miles only go up from this post.
Current TX inspection after the conversion
Current TX registration as well
I average 23mpg without a proper tune (should be capable of high 20's/low 30's)
Manual glow plug circuit
factory tint
transmission default shifts
winch was removed
New tires/alignment (tires at 70-80%)
Known Problems:
Headliner needs to be reupholstered
trail driving scratches (clearcoat scratching)
interior has no tears, but is worn. (driver seat is close to worn tearing on the bottom cushion cover)
Time for front CV shafts
Stock Tachometer was the only thing in the conversion I did not finish to get working
No cruise control (did work after the conversion but I broke the cable)
Drivers seat belt does not retract all the way
Front windows are a little slow to come back up
No radiator shroud
![custom (24).jpg custom (24).jpg](https://expeditionportal.com/forum/data/attachments/102/102496-7756ffb779a31aa0e9498843d32d4d51.jpg)
![431797_10152805978400564_1437303227_n.jpg 431797_10152805978400564_1437303227_n.jpg](https://expeditionportal.com/forum/data/attachments/117/117129-5d8a6fdedf3481bb1e44e493ecb742a6.jpg)
![946157_392264387553740_290645968_n.jpg 946157_392264387553740_290645968_n.jpg](https://expeditionportal.com/forum/data/attachments/117/117130-0f326614f2d20609d1ab52b465728910.jpg)
Link to my photo album of the xterra Here
PRICE is $15k Also will take trades or partial trades in consideration
A/C blows cold
New water pump
New belts
SE Trim
factory tint
winch was removed
Known Problems:
No radiator shroud
