For Sale: M1101 Based Expedition Trailer....
rbaz
$8500 OBO
I am wanting to sell my trailer. Built it up beginning in 2015 and finished within that year. It was taken on a few overland adventures with the family and we had some great times in all 4 seasons. Since 2020 it has been used once a year for a 24 hour mountain bike race that I compete in and stored otherwise. It would be great if someone out there could get it out in the wild and use it as it was intended. I put a-lot of thought into the design and it works very well. When tent is deployed there is room for a 6-6’3” person to walk underneath overhang in annex. I always towed it with my FJ 80 with a 6” lift and trailer height was perfect. It is a little heavy for an 80 so it was slow going up the hills but it tows very well. If you have an 80 you know what I speak of. It has a Pintle Hitch and I never changed it out because it was easy to operate and not noisy etc. I removed the Military Wheels and replace the drums for Toyota compatible units and have 35” BFG KM3 Muds on black powder coated Landcruiser wheels.
Here is a list of Things worth mentioning:
-Custom Made Roll Cage Style Tent Support Structure With Hinge System to allow for Elevated Sleep Position
-Tepui 4p Ruggedized Tent with Zip on Annex/Changing Room and dual density Mattress (Bed 96”x72”)(In very good shape for age)(No bad smell or wear)
-Tepui 6x6 Side Mount Awning
-Pull out Kitchen with Sink (Hot and Cold Water), Mounted Coleman Stove (Plumbed with Propane)
-32 Gallon Under mounted Fresh Water Tank (Top Mounted Fill)
-Interior Mounted 12V 100AH AGM Battery
-Power Control Panel with USB Charging Ports
-2 Roof Cage Mounted Solar Panels (With Tilt)
-Electric Water Pump
-Tongue Mounted Propane tank with Dual Regulator for Stove and Water Heater
-Instant On Hot Water Heater(Propane)
-Front Mounted Shower (Hot and Cold Quick Disconnect) (I’ll Throw in the Shower Tent)
-35” BFG KM3 Muds on black powder coated Landcruiser wheels (Good Rubber)
-Rear 2.5” Receiver Hitch for Bike Rack
-AZ Permanent Plate and Title
It is showing some age but a few cans of spray paint and some elbow grease would have it looking new again. Here is a list of things that could be replaced to make it look new again:
-Replace some of the wiring to the Solar Panels (Cracking in a few places)
-Charging Controller LCD no Longer Functions but unit works fine. Battery is always Charged.
-Repaint the Roll Cage
-New drawer faces
-Install a new Tent Cover (Sun is Starting to fade it)
-Side Mounted Shade could use a new cover
……..I am in Tucson AZ….. let me know if you are interested. I can send more picture and answer questions.
Here you go...... It slides out from the side and I have two posts that hold it up at the end that can be adjusted to suite whatever the terrain calls for when parked. It pulls out to about the stove before they need to be deployed so if you just need to have a surface to do some prep work you simply slide it out with out supports. It is made of ABS/Delrin? plastic other than the drawers.With the main structure being plastic there is no need to worry about moisture or warping. I made the drawers out of baltic birch and they could use some refinishing.
M meadow build
