Ford 4x4 van questions
darrenb
Hey guys I have a 1999 ford camper van. It was my father in laws, he lowered the camper van body onto a 1999 ford 4x4 van with a V10. My first question is how to identify if the 4x4 van frame and drive train is a E250 or E350. By the looks of the rear end I think it's a 350 but not sure. I can post pics if needed thanks
darrenb
Here are some pics. I would also like to know if this is a quigley conversion 4x4 kit. Thanks
darrenb
I need to replace the tie rod ends on the the frontend, but I don't know if 2WD would work or if I would need 4wd tie rod ends.
ujoint
Supporting Sponsor
Could be either, you'll need to call Quigley with the VIN # to get the part #s for replacement parts.
They're not stock E series 2wd parts.
darrenb
How do you identify 250 from 350? And the tie rod end I need is the one conected to the pitman arm. The problem is I have no Vin number from the 4x4 van only the original ford Vin. I could post a picture of the vin if it will help. Thanks
ujoint
Supporting Sponsor
Call then with the vehicle VIN#. They don't sell a kit, only install at their place.
Eaglefreek
Eagleless
Quigley will only have the VIN on file for the van they originally built. If your dad put his van on the Quigley chassis, the vin of your van is useless. There should be a VIN stamped on the frame somewhere. Just have to find out where Ford put them on that year van.
darrenb
My father in law was smart enough to pull the vin sticker off of the quigley van. So I do have the vin #. I have already contacted quigley through email requesting a parts list and will be calling them also. I read somewhere that the tie rod that I need (tie rod connected to pitman arm) might be a moog. Thanks
Tdavis8695
