Ford e350 7.3L UJointoffroad - Yeti
iin10ded
that it? beastly.
kchristian
Looks pretty sweet. Can't wait to see more pics. What's the story behind the 2000 van with the 2003 7.3? is the 170k on the motor, van or both?
chadlanc
The body was a donor and went thru a complete frame off restoration at Ujointoffroad. The engine/transmission were from an ambulance with 108k miles. Pretty much everything on the donor was replaced Body Mounts, Alternators, AC Condenser, Glow Plugs, Injectors, Injector harness, Engine Control Module, Injector Control Module, Fuel tank, Rebuilt Transmission with Heavy duty Torque Converter, Turbine speed sensor and piggyback, Rebuilt Rear Axle, Rebuilt Front Axle, Fuel Pump, Custom Driveshafts, U-joints, Brakes (Complete), & more. The donor van kept its body, dash, frame, and rear axle housing.
Clemtiger84
