Four Wheel Camper for sale -- Fits IH Scout 4x4
Stan@FourWheel
Just posting this for one of our customers.
I don't know anything about it, but it looks like a good deal if you have a Scout.
Please contact the seller directly if you have questions.
Thanks
__________________________________________________________________________
I sold my Scout and the buyer didn't want the camper.
Only the camper is for sale (Scout Not Included).
This could fit on a K5 Blazer, Bronco, or 1st Gen 4-runner with some modification.
$1,300 obo Located in Northern California (Bay Area).
This is a one-of a kind setup. It will bolt onto any Scout 2, but will require some drilling around the tailgate to seal it properly. You can still bolt it on and drive- off securely without drilling. It's sitting on camper jacks and ready to mount (I will help with the process)
This thing breaks down and sets up in 2 minutes. When we got to camp late, in the rain, my wife could pass through while I spent 30 seconds outside unbuckling the latches. After that, you pop it up from the inside and you're ready for sleep. Make some soup and brush your teeth while you're at it. The best part: Four season camping in comfort.
1990's "Blazer" Fourwheel Camper (designed for Chevy Blazer, modified to fit Scout)
6'-6" wide (Scout is 5'-6" wide)
Pass through!
6'-4" when popped-up (on Scout- varies with bed depth of other vehicles)
48" x 6'-6" bed over cab
Insulfoam insulation with Tyvex tape over aluminum support
Lightweight aluminum frame over two layers of ¾" plywood
Replaced aluminum siding with aluminum sheeting
Aluminum angle at all corners
2 roof vents with screens (one aluminum, one polycarbonate)
4 windows/ vents with 4 layers (storm flap, privacy flap, clear vinyl window, screen)
Vinyl is in great condition
20 lbs. propane tank with Atwood 12,000 BTU furnace (motor may need replacement- $75)
2- burner Wedgewood stove
Stainless steel sink with hand-pump faucet
2.5 gallon Reliance tank (removable)
Huge storage capacity under counter with 3 cabinet doors
Attached using factory frame-rail and windshield frame mounts (windshield mount not needed for half- cab trucks)
OR Fab tire carrier mounted with interior steel bracket that bolts to vehicle floor
Holds 2 Jerry cans (bracket can be ordered to hold Nato/ Scepter cans)
Holds hi-lift jack and tabs for antenna/ rear light
Aluminum roof rack
*Couch/ rollover bed went with Scout. Not included.
Comes with passenger side window. Just cut a hole in the aluminum, remove the screwed- in braces, and it will sit in the existing frame.
Located at my father-in-law's shop in Antioch, CA
Reply to: scoutcamperforsale@gmail.com
shortbus4x4
Looks like a nice camper. Try putting this up on binderplanet too, they seem to like Internationals on that website.:)
iStan814
