FS: **SOLD*** 1998 Mitsubishi Montero with rear locker and 4.90 gears
Cosmos99
Selling my rust free 1998 LS Gen 2.5 Montero. Located in Colorado I have had this for 3 years and it has performed flawless and is very well maintained. It comes with a bin of spare switches, bolts, oil filters, etc. Mileage is at 231,224. I have put almost exactly 15k on it. Big highlight is the valve guide seals were done prior to my ownership. Burns zero oil and there are no leaks. Under my ownership I had the heatercore rebuilt with a new brass core. Heat blows hot when outside temp is above 20 degrees, below that it's warm. I suspect I have one of the blend doors misaligned as the heater fan blows slightly less powerful than when its on A/C or full cold with AC off. Other than that the only other know issue is the horn suffers from the same cold temp problem as most other monteros and will honk when them temps are very well below freezing. I just pull fuse during that time. All maintenance is up to date. Included with the sale are brand new lower control arm with uninstalled siberian bushings. I will change the oil prior to sale. This is my 4th Monty, I love them but I started a business 1 month prior to the pandemic start and want the extra funds to expand the operation. In the below list will be a link to a google drive gallery of pics and the previous owners build thread from this forum. Feel free to contact me with any questions. Best email is ed@concorsoautodetail.com
PRICE: $8500 or nearest offer
WORKSHEET Attachments is at the bottom
BUILD THREAD / PREVIOUS OWNER MAINTENANCE
https://expeditionportal.com/forum/...ls-build-adventure-thread-black-betty.162425/
PICTURE GALLERY
https://drive.google.com/drive/folders/1rBa_4m4WRkMzFUwm8zbs1aVaMwrbR2sg?usp=sharing
UPGRADES and MAINTENANCE
Rear locker from Montero SR
4.90 gear swap
33” BFG K02 tires with 50% life
Brand new lower control arms and siberian bushings ( new in box. Arms and bushings not installed on the rig )
Aisin Manual hubs with correct wiring to allow 4wd drive lights on dash to work
Valve guides and seals done prior to me. This Monty burns ZERO oil and has no leaks
JAOS front skid plate
A.D.D. transmission skid ( currently off needs new hardware but comes with sale )
OEM timing belt, water pump done 24k miles ago so you have 40k left on it
OME rear coils
OME front torsion bars
Heated cloth “ bouncy” seats for both driver and passenger
Trailer hitch and brake
A.D.D. Idler Kingpin
Oil changes every 4k with Valvoline high mileage synthetic oil
Fully polished to remove pin stripping, scratches and then ceramic coated
interior was just detailed to remove any dust from Arizona, Utah and Colorado camping trips
Heater core fixed ( this a huge job and most Gen 2 monteros will need this done ) with new brass core so it will be good for another 20 years
New climate control console
OEM exhaust manifold for passenger side
New rear brake rotors, pads, passenger rear line and caliper. Pads are centric ceramic
new front brake pads centric ceramic
Brake build was just flushed 200 miles ago
New KYB gas a just shocks less than 100 miles ago ( also have KYB MonoMax have 7-8k on them )
replaced oil cooler return line with OEM line
New OEM coolant flush
New fenders to replace the dented / holes drilled ones that had a snorkel
Alignment 200 miles ago
tires balanced 10 miles ago
giant box full of parts, extra switches for windows, heated seats, defrost, diff lock, seat belts, OEM bolts and hardware
2 spare oil filters OEM
Cosmos99
A few pics
Eli_ATX
Love these 2.5 Monteros, and seems like great value here. Tons of work and looks in great shape for the mileage. If i were in the market for this I'd be all over it.
eclipse179
