GME making a move
Remember that CCTS is not a split tone type privacy tone. DCS is a split tone type privacy tone. I have a cheap set of FRS Midland Hand Held radios that can use both. My Midland. MXT275 and MCT575 were able to use both CCTS and DCS. When in CCTS it was a single tone regardless. When in DCS it was a split tone for TX and RX. It was something I had to take time to learn.
With GME it is the same rule. If you use CCTS the. You are not using split tone. If you are using DCS then you are using split tone.
Exactly, just like T and TSQ. One is encode only the other is encode/decode for CTCSS. The GME doesn't seem to be able to do the encode only as it was designed and sold to do.
CTCSS is continuous tone-coded squelch system and DCS is digital code squelch. They can be single transmit or receive or both on TX and RX. The difference is CTCSS is analog (and is the same thing as PL Tone, which is Privacy Line, a Motorola trademark) and DCS is digital codes instead of a sub-audible tone.
Split tone just means you have a different tone or signal on TX than RX. That's not unusual on repeaters because a listener can scan for the tone being used on the output that you hear and if you use the same tone on input they can maybe sneak in unauthorized. By using a different tone on input you can prevent this. To get into the repeater someone would have to try all possible CTCSS/PL/DCS. Tedious at least.
Having a tone on the output of a repeater is only for courtesy, you will always hear the output tone or not. If you use a tone to open your squelch on RX it's usually because you have interference so it's double step to prevent static. You only really need to be able to add a tone or DCS to your TX signal if the repeater is set to require it.
Yep, pretty simple. Problem that I came across was I set the global to 156.7 TX only for the local repeaters. Went to the next county over and went to use one that is CSQ only (dumb actually but that's a different story) and tried it. Saw the speaker light up on the radio but no audio when the RX side was set to off. Turned off the TX tone and only then could the repeater be heard. The hard part is getting GME to understand it doesn't work correctly. They are probably great engineers, just not end users that understand how radio works.
So, other than GME being only 5W, which is fine for this HAM and basic line of sight comms, it seems like a much better choice than a 25W or 50W Midland or one of the various Chinese options.
More or less yes. With my experience with the MXT275(15 Watt) and the MXT575(50 Watt), the range was there, but the sound quality wasn't. With my GME I won't argue that the Range isn't as much especially with the 2.1Dbi Antenna, but the Sound Quality is Fantastic! I also like the Volume Control on the GME over Midland. On Midland you have 1-9 and I had trouble hearing at 9 most of the time. For GME you have 1-31 and I can respectively have it set around 14 and hear just fine.
Thanks! I plan on using their ~6db antenna, so that will help the "power" factor some with a ~4x boost in radiated power. Since I'm only reaching out to my handsets, that should be a good overall solution.
And thanks for clarifying the sound quality and volume improvements over your previous Midland radios.
Regardless if you have the Medium Duty or Heavy Duty Antenna, I would recommend having both the 2.1 Dbi and 6.6 Dbi Antenna. You will find both to have their place and it's easy to change on the road
Why the 2.1 Dbi antenna? Is it just the overall length, or something to do with getting other people's conversations stepping on your own?
Has to do with how the signal is projected. Not to say the the 6.6 Dbi is bad necessarily, but more of the fact that if you are in more hilly situations the 2.1 Dbi will be best since it cast more of a ball type signal vs the 6.6 Dbi that is suited more for flat open terrain as it cast a much more narrow beam.
Aw, beam width. Generally, these antennas are omni-directional. Radiation 'lobes' should not be a problem on true Omni antennas, though reflections and ground clutter can affect things.
Still keep in mind the overall terrain. It will be the biggest affecting attribute to how well it will do. Thankfully the CB Radio in Australia is very close to GMRS on wavelength. Ronny Dahl in Western Australia did a test between the 2.1 Dbi and 6.6 Dbi Antenna just to see how each would perform on flat ground(with some minor changes in elevation). The test showed that a 2.1 Dbi was a bit better for most of the test. The 6.6 did well in its own ways, but still had issues.
Here is the video with said test.
That 2.1Dbi antenna did a lot better in that test than the taller one. The "Omni" beam profile also seems to be a lot better for general use, especially if roof-mounted. This also omits the fact that its shorter height means you won't hit as much stuff overhead if you don't take it down or fold it.
Super helpful! THANKS!
ELShockley
