Hankook Dynapro M/T Tire
So, would they be acceptable for my needs? I think the they should be more then enough protection for my needs, specialy for Baja! Your thoughts in deep sand , rocky terrain! Also they seem very similar to the Toyos Mud terrains, however they do not carrie the size i need for my vehicle!
i had the hankook all terrains, uhhh Z36 or something like that, in a 31 on my truck before the bfg's, and they gripped real well on road and off, probably as good as my bfg's, except in the snow. also, they only lasted about 30k (km), and they were done!
Im running the Hankook's MT RT03 (295 75R16) and so far (2 trips) they've worked just fine. I have zero complaints, but it's way too early to tell. The price was a deciding factor because i was trying to get the most bang for the buck and build my rig in a 8 week period before it's maiden voyage.
Great! glad to hear somebody has some experience with the tires, how much noise do you get compare to bfg all terrains, how good are the side walls when you air down? and were they difficult to balance. Thanks!:exclaim:
Well i just aired them down on Saturday for a run and just air'd them back up today (yes tuesday) and no problems whatsover. Ran on the fwy @ 55mph for a few minutes too. I never felt the side wall for heat though, i should have. They're rated for load D. They seem quieter than the BFG mud-terrain t/a's ive owned. They were like normal mud tires balancing when new.. i won't know till i go back in again for another balance later on.
Here's pics the day i mounted them up.
http://rides.webshots.com/album/554160660
I got a good deal @ Americas Tire.. lemme check my invoice..
I had them match their Americas Tire Direct website:)... and they covered the shipping that way too hehehe
Great looking truck, it looks very good with the Hankooks! I just hope they are not overkill for my 4Runner sport V8. I got a quote on the tires 164.00 each.
I am considering between the Hankooks and Chuck's Maxxis, he mentions lower noise then his Geolanders, so I am trying to decide between the two tires for my 4Runner on a 265/70-17" tire size, any suggestions or comments other then the load range between this two tires!
http://www.maxxis.com/products/automotive/product_detail.asp?id=282
http://www.discounttiredirect.com/direct/findTireProductCategoryDetailBrnd.do?tpc=HANVM1&tp=Truck%2FSUV
The Dynapro MT RT03 is a rugged tire designed for "true off-road drivers." The V-shaped tread blocks are tapered for better grip in mud or sand and you should see them perform in snow. There are "ejectors" built into the tread grooves to prevent stones from penetrating. Specifically designed shoulders keep dirt from building up and to help prevent damage from impacts.
HButton
