We fixed our injector problem in North Dakota by having two injectors replaced, but now our 2006 Isuzu NRR 5.2L 4cyl diesel has an engine light again.
It is throwing code P238, which has to do with turbo high pressure sensing. It does this right when you crank the engine and erasing the code has it pop back up immediately.
The truck runs, we drove it 120 miles, but the top speed is now about 50mph and it can barely go up hills. Admittedly it was never speedy with our 18,500 pound load but it was able to do 65 or 70 on a flat.
We are near a truck shop in Dothan, Alabama which does work on Isuzu but this would involve removing both pods from the flatbed, which takes a couple of hours, then a couple hours to re-pod. If this is just a boost sensor, loose cable, or something that I can get to myself, it would save us a ton of work.
Any ideas?
Any ideas?
