DakarTJ
I am using the courtesy light circuit as a control signal to a relay. The relay will power my rock lights. I am doing this so when I open one of the doors the ground is lit up. It will come in handy at night trying to get out of the jeep. I got it all working so the open door will trip the relay or a switch when the doors are closed.
The issue I have is the Jeeps slow dimming of the courtesy lights when the key is out of the ignition (this is normal). The Jeeps signal to turn off the courtesy lights is a rise from 0.0v to 12v. This slow rise in voltage causes my rock light relay to shudder from about 3v to 9v where it latches. With the key in the ignition the fade does not happen so all is good that way.
I tried to fix this with a 1N4742A, 1-Watt 12v Zener Diode. My thought was the 12v reverse breakdown voltage would stop the rise in voltage from getting to the relay until it hit 12v; then break down and let the current pass to the relay. This did not work. I think the current might not be adequate to push the diode into break down; or the voltage loss across the diode will not let it get to 12v.
The door switch acts the same way in the jeep. The whole circuit runs backwards from the rest of the Jeep. 12v to turn off the lights and 0v to turn them on; I can't find the part of the circuit that's before the dimmer. I think its logic in the computer.
Sorry this is so long, but can you help. Is their a better diode to use?
