off-roader
I started to inquire on another thread why folks finished their storage systems using finishes that I'd think wouldn't last in the dirty environs synonymous with off road use.
To clarify the use further... for my application off road the surface will have tools, steel/metal hardware thrown on them regularly and in some cases have to travel short distances (10's of yards/meters) with tools atop before I can pull over to a safe location and store them.
What are you all using to protect your storage systems from the elements? dirt? sand? dust? etc.
I've made several storage systems for my various 4x4's over the years. 2 were made using exterior grade carpet and one using exterior paint.
CARPET
Carpet definitely handled the abuse better but over time I found the dirt got into every fiber making it too dirty to use (even after vacuuming)! Only solution was to replace the carpet but unfortunately, I had used glue along with staples to adhere the carpet to the wood.
PAINT
Unlike the carpet which still looked nice the exterior grade paint DID NOT handle the off road abuse well at all and the surface easily marred and dented and the wore through the paint. I won't be making that mistake again.
I imagine (although I'm not keen to try and 'personally' verify it) other finishes like clear lacquers, or polyeurethane will also have this problem.
Other options I've considered...
Melamine: Nice smooth & easily cleanable surface but would it wear well?
Perhaps there's a Herculiner type of product but with a smooth texture that's easily cleaned and able to handle the wear.
Replaceable black uhmw material would be interesting too but I'm not sure if the cost would make it unreasonable.
Vinyl fabric over the wood surfaces: Easily cleaned, easily replaced.
Thin 'rubber' sheet material (is this readily available in the US?)
Any others? What actually works?
TIA:coffeedrink:
CARPET
PAINT
TIA:coffeedrink:
