waveslider
Outdoorsman
The question: Given the realities that most modern diesels are light years better than vintage trucks in regards to cold-temp starting and running, I'm wondering if anyone has specific advantages or disadvantages of hydronic vs non-hydronic type systems?
We are currently faced with a decision between utilizing a hydronic-type air and water heating system (which for the record is the style we are familiar with from other vehicles) or using a non-hydronic diesel heating system. Aka: the choice between Webasto Hydronic Thermo Pro vs Webasto Dual Top Evo
Obviously, if you have an older truck that isn't particularly a fan of the cold, or you are looking to explore in some true corner-case cold environments where engine preheating is a true necessity, then the choice is clear. But for a modern truck that doesn't need the preheating capability, I'm wondering if there are advantages of one system over the other? Clearly, Hydronic is more expensive - looking for justification for that.
System Simplicity? Maintenance? Dealing with Cold Weather (outside of the engine preheat argument)? Efficiency?
Thanks in advance for insights and opinions.
