So far, so good. Only suggestion I would make would be to try and incorporate your hitch into the bumper. Could score a few more inches of clearance and departure angle that way. Looking forward to the end result....
Looking good. You can put some 3m grip tape on the top for a secure step. I would leave the stock reciever in place so you wouldn't have to use an extremely long drop hitch.
I thought of including the hitch on my burb's new bumper too. But I thought the hitch hanging kinda protects the fuel tank on mine. If I took it off then the first thing to ********** would be the tank, not the hitch. Just thinking....is it really a good idea to remove it?
Way back while in College I built Patch's front bumper with similar shackle lugs, and I've come to hate them. The next time around the lugs will be flush to the front of the bumper. I can't tell you how many times I wonked my head on them while climbing out from under the truck or snagged my calf on them while working under the hood. I strongly suggest aggressive rounding of all edges. I didn't go far enough.
My '91 Sub has the OE skid plate under the 40 fuel tank. My '79 did too, only they're still sitting on my driveway long after the '79 got scrapped. PM if interested in them. I can see the point of keeping the receiver hitch, but with the overhang of a Sub that ~3" that losing the hitch buys is precious.
The bumper still needs to be attacked with a flapper disk to smooth and round all the edges before paint. Im leaving the hitch where it is due to the amount of towing i do.It has the factory skid plate on the fuel tank.
Later i'm going with 8'' lift springs on the rear that will give me much needed lift since my factory springs are shot, that will help with the low tow hitch situation and eliminate the lift blocks.
Just some food for thought, moving my receiver tube up and "onto" the bumper assembly made a huge difference in clearance. Here are a couple of before and after pics.
Of course, I am not sure just what my towing rating on the thing is now, but for the occasional chore or towing a heavy load of mulch it has worked fine.
Just a thought. Wish I could do welding on my own, I admire it, looking forward to the end result.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
